Sponsored by: Real Truck
Code Help: P0022 and P0345
Old Feb 22, 2011 | 09:26 PM
Johnis's Avatar
Johnis
Vehicle Info:
2005 Ford F350 Regular Cab
5.4L
Code:
P0022 = Bank 2 Over Retard
P0345 = Bank 2 Camshaft Circuit Malf.
Symptoms:
A few weeks back I noticed that the truck was rattling at the engine during hard decel, but the rattling was very light and faint, which only lasted about a second or so.
I checked the motor out and it was low on oil, did and oil change and the noise went away.
Then the problem grew. The rattling became more obvious and only occurs at idle and decel. The rattling was coming from bank 2. It was so severe that the motor just wants to choke out. I was able to get the car home. The next morning, drove it to a shop and it completely choked and shut off. It was sputtering and choking with backfire, the truck couldn't even move.
I had it towed to a shop, they apparently pulled the code and told me the motor was gone and it was miss firing. I towed it back home, pulled the code myself and found a number of CEL popping up, but it narrowed it down to one problematic culprit, which was the P0022. All the others were results of the balance test on the motor.
I spent hours on the site and really couldn't find much on the P0022 under the Super Duty section, but there were a handful of guys on the F150 who were experiencing the problems with this code and I narrowed it down to a Bank 2 VCT solenoid. At this point I have already checked the COP, spark and fuel, all of which checked out. I replaced the VCT solenoid last night and the truck fired up, ran through the RPM okay. Prior to the replacement, the truck would start up, and rattle/shake and choke.
Today I took it out for a ride, I still get a rattling during idle but it doesn't choke and shut off like it did prior. I pull the code once more and now, not only, does the P0022 show up but the P0345 (Cam sensor bank 2).
I also forget to mention that as soon as the VCT was placed, the erased the code and let the truck idle for 40 minutes placing it through different RPM, no rattle and no code. The code and rattling did not come back until I took it out for a road test.
Could the CPS be the culprit? anything else I should be looking at?
-John
Old Feb 24, 2011 | 02:47 PM
Johnis's Avatar
Johnis
any?
I just replaced the cam position sensor and still getting the P0022 code.
Old Jun 12, 2011 | 08:32 AM
atross's Avatar
atross
P0022 Ford Code
I'm having similar issue, did you get anything figured out? My truck is only throwing the p0022 code and it is somewhat intermittent, works fine for a week, then next week the truck is un-driveable. Sounds like I'm in the same spot you were at your last post. I believe the truck has a cam phaser issue and bank 2 needs to be replaced. Just reluctant to spend the time/$ because the issue is intermittent. Let me know your findings if you don't mind. Thank you in advance.
Old Oct 28, 2012 | 12:30 AM
Derrik's Avatar
Derrik
i have same codes simaler problems at idle and low rpm
Xcursion88
2004 - 2008 F150
Jun 6, 2018 04:06 PM
Xcursion88
2004 - 2008 F150
Sep 8, 2017 04:56 PM
rs0630
Apr 7, 2016 07:45 PM
Gfree1819
2004 - 2008 F150
Aug 16, 2015 08:10 PM
AFMSgt2012
2004 - 2008 F150
Aug 6, 2012 06:05 PM
