Diversi-Tech ball
Old Feb 22, 2011 | 07:13 PM
PITS's Avatar
PITS
Diversi-Tech ball
Does anyone else have the Diversi-Tech adjustable aluminum ball mount? I ordered one with the 6" drop and want to be sure I still have enough ground clearance. It looks like it hangs down and would catch on stuff if I am dragging my trailer through the brush. I may adjust it to where I need it and then cut the rest off if I need to. Don't have the truck yet so I am just guessing. TIA.
Old Feb 22, 2011 | 08:13 PM
lexustbs's Avatar
lexustbs
I have the 4" drop. The reason you stated is why I chose the 4. Just a FYI that the actual ball is steel. I was bummed to learn that.
Old Feb 22, 2011 | 08:20 PM
Sgt93's Avatar
Sgt93
The 6" is perfect. I own one.
Old Feb 22, 2011 | 08:48 PM
jim6090's Avatar
jim6090
2" Drop only option
My trailer requires a 2" drop to be level. i have a 4x4 SWB Crew cab with 20" tires. I had a 4" drop and a 2" extra height ball. Hitch bottomed out backing up steep driveways. Good luck.
Old Feb 22, 2011 | 10:48 PM
PITS's Avatar
PITS
Yeah Sarge, I saw in your signature that you had one and sent you a message on your public page but you probably haven't seen it if you haven't visited your Control Panel. It sounds like you have the same one I ordered. Do you have the double ball also? Do you have the factory lift height? And do you worry about dragging that inverted ball or does it have plenty of clearance? Thanks.
Old Mar 5, 2011 | 12:09 PM
porthole's Avatar
porthole
DRW or SRW?
Old Mar 5, 2011 | 12:54 PM
Sgt93's Avatar
Sgt93
There is Duane. I sold him my 2nd DT.
Old Mar 8, 2011 | 08:24 AM
Rambro4's Avatar
Rambro4
I own this same one and it fits really loose into my receiver do you have this problem?
Old Mar 8, 2011 | 10:34 AM
cjay84's Avatar
cjay84
i have the DT-ALBM6625 on my f-450 dually, the 4" one would have been fine, but the 6 hasnt drug or hit anything yet tho. i keep the ball part up almost flush with the hitch when not towing.
caiati
Aug 26, 2012 04:38 PM
Bat-Masterson
All Other Items for Sale
Jun 29, 2011 01:27 PM
Bat-Masterson
Jun 16, 2011 11:16 PM
Sgt93
6.7L Power Stroke Diesel
85
Apr 12, 2011 03:00 PM
SilverBullet131313
Oct 18, 2009 07:01 PM
