Sponsored by: Real Truck
diversi-tech
Old Jun 15, 2011 | 07:10 AM
Bat-Masterson's Avatar
Bat-Masterson
diversi-tech
I know a few on here have them, and I just picked up a 6" adjustable lockable for my 2010 4x4and I have to tell you I am a little scared to use it, it sure does not seem heavy duty enough.
Now I am use to just a drop down hitch that I bolt on a ball and then a spot of weld
The DT the part that goes into the receiver seems awful light and the part with the ***** on it seem like there is no way that pin sticking out will hold a trailer when you set one on. and the ***** even have some movement.
Some needs to tell me its all in my head and this is how far technology has come since I bought my last one 10 years ago, I just can't get over the fact that you need a heavy hunk of metal to do the job.
Just would like to know how they have worked for others, and I do think I could of got by with the 4" but better safe then sorry.
Old Jun 15, 2011 | 07:48 AM
drey04's Avatar
drey04
Mine can drop 10", my truck is lifted so I needed more. I haven't had any problems with it so far. Seems like a good hitch to me. The hitch is on my truck in my signature pic, kinda hard to see but it's there
Old Jun 16, 2011 | 10:52 AM
Bat-Masterson
Yes the 6" was to much bottomed out in the driveway
should of went with the 4" , doubt I will buy another one have a few different drops in the garage just use them, hate to spend another $190.
But they are sure nice looking
Old Jun 16, 2011 | 11:49 AM
drey04's Avatar
drey04
Yea I got a few laying in the garage too, but just wanted something I could use for whatever I tow. I sometimes leave it on the truck even when I'm not towing just because it looks cool
Old Jun 16, 2011 | 05:17 PM
bpounds's Avatar
bpounds
Can't you just cut it off and turn it into a 4"? It's 7075 aircraft aluminum, so that's not something you want to try with a hacksaw, but a shop with a bandsaw could cut it right off. Unless you plan to return it, no reason to let it sit and waste your money.
I would trust the design without any concern. That 7075 is good stuff. BUT, remember that although they say it is rated for 1500/10000, it is not a weight distributing hitch, and your Ford receiver is not rated for that much. That will be true of any drop hitch stinger you put in there, steel or aluminum, unless you upgrade the receiver.
Old Jun 16, 2011 | 05:28 PM
Bat-Masterson
You lost me on this, are you saying I cannot use the DT to pull 10,000 lbs, really don't pull that much but it is between 6000-and 9000 lbs. This is my 1st adjustable with my last 250 just had a 2 inch drop hitch.
ordered a new trailer so have not hauled anything with my new to me 2010 250
was not going to return just keep it since I scuffed up the ball, thought it might weaken it if I cut it.
Old Jun 16, 2011 | 06:01 PM
bpounds's Avatar
bpounds
If you have an F250/350 single rear wheel truck, your stock receiver is a 2", and it is only rated for 600lbs tounge weight, and 6,000lbs trailer weight. (less than that for pre '05 trucks). With a weight distributing hitch it is rated for 12,500lbs. There should be a label on the receiver that tells you the rating.
So with a simple stinger (non-weight distributing), you are limited to a 6,000lb trailer. Doesn't matter whether the stinger is aluminum or steel. It's nice to have a stinger (draw bar, drop hitch, whatever you want to call it) with a 10klbs rating, but your limit is still the receiver. If you overload it too much, you will probably bend it.
As for cutting the hitch, you can cut off any amount you want below the bottom of the adjustable block. Obviously it won't be able to adjust downward any more.
Old Jun 16, 2011 | 08:23 PM
Bat-Masterson
Now I understand I had my old F-250 for so long never gave it a thought when I bought this one, had a after market receiver on my old truck that was rated higher weight.
Found a Reese for sale online for $259 specs down below
Key Specs
<table class="data" width="100%" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td class="col2">Receiver Size (in.)
</td><td class="col4">2</td></tr><tr class="odd"><td class="col2">Class Rating
</td><td class="col4">IV</td></tr><tr><td class="col2">Installation Time (min.)
</td><td class="col4">20</td></tr><tr class="odd"><td class="col2">Drilling Required
</td><td class="col4">No</td></tr><tr><td class="col2">Manufacturer Warranty
</td><td class="col4">Lifetime Limited Warranty</td></tr><tr class="odd"><td class="col2">Ship Weight
</td><td class="col4">73.0 lbs</td></tr><tr><td class="col2">Item#
</td><td class="col4">128813</td></tr></tbody></table>
  • For Ford F-250 and F-350 Pickups
  • 1200 TW and 12,000 GTW weight capacity
  • 1500 TW and 15,000 GTW weight distribution
  • NOTE: An 12,000 lb. capacity-rated ball mount must be used to achieve maximum weight carrying rating
Old Jun 16, 2011 | 11:16 PM
Pocket's Avatar
Pocket
I have a 6" drop DT on my truck that I've used constantly for the past 2 years. It's put up with every bit of abuse I've thrown at it, including towing trailers topping out at well over 10K lbs.
71-4R3SONS
Aug 11, 2014 10:25 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
May 20, 2013 12:11 PM
wrdabney
Mar 8, 2013 03:41 PM
95e150CW
13
Mar 21, 2012 11:17 AM
00Dave
48
Jun 22, 2011 12:22 PM
