Front Hub
Old Feb 22, 2011 | 07:06 PM
kadus's Avatar
kadus
Front Hub
I have a 2000 Excursion, V10,, left front hub went out, replaced it , and 2 weeks later the new one is wobbly, like the bearing is out again. I got it at Advanced Auto, so aftermarket. Can there be something else causing the issue, bad axle?
Old Feb 22, 2011 | 07:22 PM
iamme81702's Avatar
iamme81702
On sharp turns mine is doing a lite clicking does that mean its bad?
and to the OP I would have it checked at your local dealer and if its bad get the parts store to give you a refund.
Old Feb 22, 2011 | 07:25 PM
Stewart_H's Avatar
Stewart_H
I assume you have a 4-wheel drive rig?
Stewart
Old Feb 22, 2011 | 07:30 PM
kadus's Avatar
kadus
Yes, 4 wheel drive. Replaced the brakes and the front hub was loose, like bad bearings. So replaced the hub assembly. Tire feels loose again. Guess I could have a bad front hub? I am thinking the u-joint on the axle is bad or something?
Old Feb 22, 2011 | 08:11 PM
SkySkiJason's Avatar
SkySkiJason
Maybe ball joints? Did you replace the unit bearing? What are you calling 'hub'? What exactly is 'wobbly'? Got pics?
truck7575
Feb 24, 2015 07:09 AM
caleb6.9
Apr 16, 2010 08:41 PM
BII Plow Truck
Bronco II
Dec 22, 2009 07:32 PM
81 green machine
Apr 10, 2008 07:05 PM
nut1605
Jul 28, 2007 01:10 AM
