hello . just wanted to ask if you could help me figure out these codes i got.KOEO -1-3-3-4-3-3-4 ,this is the order they came using a volt meter.i am having a problem matching them up according to the chart in my haynes repair manual..i had the volt meter set on 2.5 d.c.v and the #'s are according to rhe amount of wseeps made by the volt meter.i have a posting in fuel injection and carburation systems and in the1987-1996 sections . your help is much appriciated. happy new year.
Since your truck is a '91, it uses 3-digit DTCs, and the single flash at the beginning isn't part of a code. You got code 334 twice and apparently stopped before the continuous codes could flash out, which probably erased them. If you go to the link in my post above, you'll see the proper procedure for pulling ALL the codes, how to read them, and the full list of code definitions.
