Block heater not working.
Old Feb 22, 2011 | 03:55 PM
Moto52's Avatar
Moto52
Well my block heater has stopped working on me for some reason. was wondering if anyone has changed one out before.
Old Feb 22, 2011 | 04:30 PM
PaysonPSD's Avatar
PaysonPSD
It's possible the cord has gone open. Ohm it out.
The element resistance is about 15 ohms.
Old Feb 22, 2011 | 04:38 PM
radmacks's Avatar
radmacks
Heres my story; brand new to me Ex, cut the cord from the factory spot still had the cover on it. noticed it did not seem to make much of a difference. The company I work for has the plugs with the light on them. noticed when I plugged it in it was not solid green, gave it a wiggle and it kicked solid green. Went to NAPPA and bought a tester for 20 bucks. figured out quickly one of the wires was broken inside the jacketing which still looked brand new. Cut it at the brake and replaced with a heavy duty plug from the hardware store. 4 bucks Good as new.
By the way today I drove away with it still plugged in and it was strong as the Ex itself and pulled out from the plug nicely. I would check the wire first before anything else mine was an invisible break. probably broken by a robot in the factory lol
Old Feb 22, 2011 | 07:06 PM
Rushmore X's Avatar
Rushmore X
If you do have to pull it out, make sure you have a oil pan or something to catch the antifreeze. Got a pretty hot bath when I pulled mine...
Old Feb 22, 2011 | 08:20 PM
WilsonTaylor's Avatar
WilsonTaylor
I would also check the connection at the block before replacing the heater. A stray dog chewed the end of of mine and pulled it loose from the block. It only took a few minutes to fix, but mine had been working before the dog got hold of it.
Old Feb 22, 2011 | 10:36 PM
bdrummonds's Avatar
bdrummonds
The cord is actually removable from the block heater. Just bend the keeper tabs on the washer and unplug from the block heater. OHM out the block heater and make sure it has 15 Ohms of resistance. A replacement cord is avail from FOMOCO, International, or maybe even your local junkyard.
Old Feb 23, 2011 | 07:09 AM
Ponyboychris's Avatar
Ponyboychris
And this guy has them too. Part #1C3Z6B018AA
Riffraff Diesel: Motorcraft Block Heater Cord
Old Feb 24, 2011 | 12:10 PM
JWink's Avatar
JWink
My was just bad as well. Check the plug end at the bumper, one side of the cord on mine had broke due to all the flapping in the wind. Cut it a couple inches back and rewired...good to go.
Wink
Modular V10 (6.8l)
Jan 23, 2017 06:29 PM
2gumby2
2015 - 2020 F150
Apr 6, 2016 11:30 AM
mudguts
Nov 21, 2015 04:30 PM
Guzzo
Oct 21, 2013 03:43 PM
magneto259
Nov 22, 2008 09:04 AM
