Sponsored by: Real Truck
Locking hubs
Old Feb 22, 2011 | 05:56 AM
Gregga's Avatar
Gregga
Locking hubs
Hello all
Just bought an 06 F-350 Super Duty and I have a question. Most likely a stupid question but I'm full of those. Why would this truck have locks on the front tires if I have a switch on the dash for 4 hi and 4 low? What's the purpose of the locks? My F-150 had only the switch for 4 wheel.
Thanks all
Old Feb 22, 2011 | 06:46 AM
mudfuel06's Avatar
mudfuel06
You have "auto" hubs, sometimes they work, sometimes they don't. When they work, you have the ability to switch to 4x4 sitting in the truck and not have to get out to lock in the hubs. When 4x4 isn't engaged, they act as free spinning hubs. If you know you are going in nasty stuff, you can manually lock the hubs in and go into 4x4 without waiting for the hubs to lock in. IIRC, the auto hub feature uses vacuum lines to engage the 4x4 system.
Old Feb 22, 2011 | 07:56 AM
senix's Avatar
senix
fail safe system should the ESOF not engage.
Old Feb 22, 2011 | 08:08 AM
dkf's Avatar
dkf
The previous posts filled you in on the reason. I'll add that the hub **** should be turned on a somewhat regular basis because the housing likes to corrode and seize the **** will seize and not be able to turn in the groove. A thin lubricant/anti rust spray that doesn't attract excess dirt is best. Once the groove corrodes you need to buy new hubs which are $200 each at minimum for the auto hubs.
Old Feb 22, 2011 | 08:10 AM
senix's Avatar
senix
And to add to this fine advice:
See the link.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Feb 22, 2011 | 08:11 AM
Gregga's Avatar
Gregga
Thanks for the replies all
So I should not need to have these locked unless I feel I need a "backup". I will turn them often to keep them free'ed up
Old Feb 22, 2011 | 08:15 AM
senix's Avatar
senix
I turn mine and run them once a month unless I am using them of course.
Old Feb 22, 2011 | 05:06 PM
F3r5e0d's Avatar
F3r5e0d
I was going to post this same question..what i still dont understand is if i manually lock the hubs am in 4 wheel drive or do i still have to go inside the truck and also put it into 4 wheel with the dash control.
Old Feb 22, 2011 | 05:28 PM
senix's Avatar
senix
dash control is still required to engage the transfer case.
Old Feb 22, 2011 | 05:30 PM
bpounds's Avatar
bpounds
If you look closely at the hubs, you will notice that they say AUTO and LOCK. There is no UNLOCK position. Knowing that pretty much clarifies how they work.
See the link.
Some useful info there, but noteworthy that the '05 and up hubs are redesigned and do not look like those on the Guzzle page. The newer ones are less prone to failure as well.
You are not in 4WD until you turn the **** on the dash. Until you do that the transfer case is still disengaged.
cattlerancher
Nov 27, 2014 08:43 PM
vf150
1997 - 2003 F150
Aug 9, 2013 02:33 PM
jenkinsj
Electrical Systems/Wiring
Mar 10, 2013 08:14 PM
plb150
Offroad & 4x4
Apr 9, 2004 09:48 AM
