another frame coating question.
Old Aug 29, 2011 | 04:48 PM
  #31
4x41977's Avatar
4x41977
Getting ready to paint frame and axles next week with por 15 how much would be needed you think. The stuff is little pricey compared to rustoleum so don't want to over order
Old Aug 29, 2011 | 05:25 PM
  #32
fordman75's Avatar
fordman75
That's because comparing Rustoleum to POR-15 is like comparing chrome spray paint to Chrome plating.
Old Nov 7, 2011 | 09:35 PM
  #33
AndrewWV's Avatar
AndrewWV
I would really like to paint the frame, axles, etc. of my 2001 Excursion with POR-15. However, given that it is not remotely practical to strip it down to the frame and sandblast it, I know that there will be places that are unreachable to be painted. My concern is that this will allow rust to get a start in an uncovered area and work its way under the paint. I figure if that happens I'd eventually need to strip the area and repaint it, but that's probably near impossible with POR.
Am I being paranoid or would it be better off to go with something like Rustoleum's rust preventer that would be easier to scrape down and reapply if needed in the future?
Also, I noticed that there is some rust beginning to form around the body seam where the running boards attach. What is the best way to clean and seal that before it gets out of hand?
Old Nov 13, 2011 | 08:36 AM
  #34
05Xdriver's Avatar
05Xdriver
Rhino skin undercoat works great and works great so I hear.
Good luck
Old Nov 13, 2011 | 08:48 AM
  #35
BrianG2's Avatar
BrianG2
Check out this thread. There are some answers for what I used.
https://www.ford-trucks.com/forums/1...oration-5.html
Old Nov 17, 2011 | 10:03 PM
  #36
Blue and White's Avatar
Blue and White
I have used Rust Encapsulator and Red Rustoleum. Both work well and prep is similar. Clean/de grease/pressure wash (or steam clean), Remove any loose rust or scale and prime. I just did a '79 F250 frame this way. After cleaning, I used a needle scaler to remove loose rust, red rustoleum primer and SG black rustoleum finish coat. The red rustoleum is less costly than rust encapsulator and takes longer to dry. Both are great products.
WallaceSF
18
Sep 10, 2016 10:04 AM
buckshot047
Jan 8, 2014 03:05 PM
Roger T. Pipe
Oct 21, 2013 07:49 PM
1964FORD4ME
Jun 28, 2006 03:14 PM
1ole4d
Apr 15, 2005 11:34 PM
