Rough idle?
Old Feb 21, 2011 | 12:51 AM
FordGod1's Avatar
FordGod1
Exclamation Rough idle?
Hey guys, Im still farely new so if i receive help and takes me awhile to reply im sorry. So thanks ahead of time!! But to my point. I noticed ever since i put 3" dp and 6637 filter on idle has been high almost 900rpm.. Not that those to mods should have anything to do with it. Is there anyway possible that i could turn it down without messing with the TPS?? Thanks again guys.
Old Feb 21, 2011 | 02:07 AM
Muktown's Avatar
Muktown
Idle is controlled by the pcm and there is no way to adjust it. Is it 900 only when you first start it or is it 900 when the engine is warm? Any difference whether it is in park or gear? Auto or manual? How old is the oil and what grade?
Old Feb 21, 2011 | 12:07 PM
FordGod1's Avatar
FordGod1
Its like that at idle and when warm. oil was just replaced 50 miles ago. its mobile one synthetic. no difference when in gear or park, auto. hope that can help find an answer.. :/
Old Feb 22, 2011 | 08:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Was the idle that high before the oil change?
Did you use Mobil 1 Turbo Diesel Truck 5W-40 oil?
Old Feb 22, 2011 | 08:40 PM
Action4478's Avatar
Action4478
PCM should read ICP & do its job from there pertaining to idle ...(TPS is in charge to begin with ...)
What year is your truck ?...
Old Feb 22, 2011 | 08:52 PM
F350-6's Avatar
F350-6
Any mods to the truck? Does it ever idle normally? Maybe try unplugging the ICP sensor or IAT or EOT sensor just for grins.
Old Feb 22, 2011 | 09:06 PM
Action4478's Avatar
Action4478
Rough idle Or steady Idle at 900 ?
Old Feb 22, 2011 | 09:52 PM
Muktown's Avatar
Muktown
Is it possible the ebpv is sticking closed? When it operates does it increase idle rpm to overcome the higher load on the engine? Its been so long since I've had an ebpv plugged in I don't remember
Old Feb 25, 2011 | 05:56 PM
FordGod1's Avatar
FordGod1
Unhappy
Its a steady idle at 900, 1996 f-250, i deleted the ebpv and rebuilt turbo. have superchip in it but i know thats not the problem because i took it off and it made it rough idle at 900. I tried the EOT and it didnt change anything.
Old Feb 25, 2011 | 06:44 PM
Action4478's Avatar
Action4478
Unplug the ICP sensor & start it , see if it makes a difference ...
strokin'_tatsch
1997 - 2003 F150
Dec 28, 2017 12:14 AM
General Geoff
Dec 29, 2014 05:29 PM
vboxingguy
Apr 5, 2012 09:51 AM
Boss351Tom
3.8 & 4.2L V6
Dec 4, 2009 11:21 PM
LA_BigRed
28
Dec 3, 2004 11:59 AM
