'97 F-250HD, idles nice until throttle is opened
Old Dec 28, 2014 | 01:34 PM
General Geoff's Avatar
General Geoff
The truck starts and idles nicely, until you touch the throttle, then the engine will rev accordingly, but not drop down to normal idle. I don't have a tach so I'm not sure what RPM it's racing at, but it sounds like between 1000-1500. Did the old carb cleaner trick and sprayed down all the vacuum tubes, no change. Has a new idle control valve, and has clean butterfly valve areas. CEL is not lit. Any suggestions guys? Thanks.
Old Dec 28, 2014 | 01:38 PM
Conanski's Avatar
Conanski
Originally Posted by General Geoff
. CEL is not lit.
Doesn't matter.. pull the codes and post up what you get.
Old Dec 28, 2014 | 04:55 PM
General Geoff
I think I found the problem, the TPS is very wonky. Checked with a multimeter, and the voltage spikes all over the place once the throttle is touched. Was at .97 volt with throttle closed (and not touched since key on), but as soon as the throttle was touched, it spiked to 5 volts, and then moved up and down between 0.2 volts and 5 volts, seemingly at random.
Old Dec 29, 2014 | 05:29 PM
General Geoff
Replaced TPS, and a vacuum line that was completely MISSING. Truck idles like a dream now.
oldproudvet
Nov 1, 2018 07:29 AM
Domestic_Nuwbee
Jan 19, 2011 07:17 AM
98FordTruck
1997 - 2003 F150
Jan 2, 2011 07:33 PM
Dales F-350
Jan 2, 2010 09:34 AM
olderguy
Nov 29, 2005 08:11 PM
