where do the chips go and a question (hypermax)
Old Feb 25, 2011 | 08:03 AM
97XLT4X4's Avatar
97XLT4X4
when i bought the truck,it had a hyper-max 300 chip in it. The trans seems to shift out of 1st late, as in it holds first. Im wondering where the chip would plug in on the 96 in my sig. can i remove it and see if the chip is causing the shift delay?
Old Feb 25, 2011 | 08:06 AM
Robbgt's Avatar
Robbgt
3 bolts hold the parking brake pedal bracket in, pull those and move the bracket out of the way. You should be able to see the PCM and if there is a chip, it would be plugged into the back slot of it. Always a good idea to disconnect both neg battery cables, of if you're lazy like me, you can pull the PCM fuse under the hood (#22 IIRC??? double check that first)
Old Feb 25, 2011 | 08:14 AM
97XLT4X4's Avatar
97XLT4X4
ill pull the posts off the batterys
Old Feb 25, 2011 | 02:21 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Eghhh... Don't bother unhooking the batteries or any fuses. Just put your keys in your pocket and your good to go. As long as the ignition is NOT ON, then you will not have a problem. It is when you pull the chip out of the J3 port or insert a chip into the J3 port with the ignition ON that kills the PCM or the chip or both. So like I said, as long as your keys are in your pocket, your in good shape.
I can see wanting to be safe, but disconnecting the batteries for a 5 minute job... Nahhhh, not neccessary if you leave your keys in your pocket...
Old Feb 25, 2011 | 07:23 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Here you can see one type (Banks) chip is located
Boyd254
Oct 25, 2020 01:28 PM
genscripter
23
Apr 12, 2016 01:30 PM
95BroncHO
1978 - 1996 Big Bronco
Jun 24, 2014 02:10 PM
Davepomrenke
22
Jun 7, 2013 05:44 AM
viperrtblck
Feb 19, 2006 07:41 PM
