HELP!!! 1975 Dash Problem.
Old Feb 20, 2011 | 03:52 PM
smoketaz's Avatar
smoketaz
Anyone know why my fuel gauge and temp Gauges would be reading to the left? I have been chasing this electrical monster for over two weeks now and am going crazy. Just got my turn signals and alt and high beam lights to work today and I have traced all the wires and have checked them all. I have replaced the voltage reg now also. Driving me crazy. Need some help please.
Old Feb 20, 2011 | 04:01 PM
Crewdcab's Avatar
Crewdcab
Probably the oil pressure gauge as well. There is a voltage regulator on the back of the instrument panel that these three gauges use. It is small and rectangular, plugs in like a 9V battery. That is the most likely culprit.
Old Feb 20, 2011 | 04:12 PM
smoketaz's Avatar
smoketaz
Thats the one that I have replaced already. I have also replaced the box where the wires go in the engine compartment. Would the volatge reg by the battery have something to do with?
Old Feb 20, 2011 | 04:16 PM
Crewdcab's Avatar
Crewdcab
Not sure on the main regulator. Did you use a new or used one on the instument panel? I've had lots of used ones from parts yards that were inaccurate as well. If you know someone with a similar truck, see if you can try theirs. Never bought a new one, so don't know if some are junk or not.
Old Feb 20, 2011 | 04:33 PM
smoketaz's Avatar
smoketaz
Replaced it with a brand new one. Can not figure this out. no F100 in this part of the AZ where am stationed at.
Old Feb 20, 2011 | 08:15 PM
sly_buck's Avatar
sly_buck
keep posting your progress, i started looking into the same problem today and really want the gauges working
Old Feb 20, 2011 | 09:36 PM
fmc400's Avatar
fmc400
MSEE
The charging system voltage regulator (on the inner fender) has nothing to do with it. It just happens to have the same name.
These gauges read resistance. Take the fuel gauge for example - the sending unit in the tank is a variable resistor. As the fuel level goes down, the resistance in the sending unit increases, which makes the current through the fuel gauge decrease. This causes the needle to point toward the left. The temperature gauge operates on the same principle (the sending unit is also a variable resistor).
If the gauges are pointing all the way to the left, then no current is flowing through them. This can happen because they're not receiving power. I know you said you replaced the instrument cluster voltage regulator, but make sure it's actually providing power. Check the output and you should see on the order of 5 volts. The other reason this can happen is because the sending units are not properly connected to the gauges, which will open-circuit the gauges and make them read all the way to the left. Double check the wiring and that the sending units are connected. The temperature sending unit grounds by threading into the engine block, and the fuel gauge grounds near the tank.
Old Feb 21, 2011 | 09:56 AM
Crewdcab's Avatar
Crewdcab
Are they pegged out left, or just reading left of what they should be?
Old Feb 21, 2011 | 10:03 AM
woodys ride's Avatar
woodys ride
i have the same problem kinda but my dash wont work at all any guesses got a new dast though the old one burnt up but now the new one doesnt work eathire
Old Feb 21, 2011 | 01:19 PM
Kalve's Avatar
Kalve
are there any lights or anything else acting up on the dash besides these gauges? An what was you doing when it started acting up? Did you change anything out on the truck before the problem started?
Old Feb 21, 2011 | 01:53 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The aftermarket ICVR(s), (Instrument cluster voltage regulator(s)) that you buy at local parts stores are made in china, and have been known to be bad or innacurate right out of the box.
Best bet, is to get a used "Factory" one out of the wrecking yard, or bite the bullit and buy one from Ford if you still can do so.
The ICVR has to have a good ground connection. The ICVR is bolted to the printed circut using a bolt headed screw. You can add a ground wire to this mounting bolt, and ground the other end to clean dash metal to insure a good ground.
The ICVR also has a place where you can adjust them to regulate how high or low the gauges read by turning the adjustment. I do not recommend using the adjustment unless you know what you are doing, as this can totally make your gauges read out of whack if you do it wrong. Do a search on the website for ICVR adjustment.
Old Feb 21, 2011 | 04:17 PM
BiltFordTuff's Avatar
BiltFordTuff
have you tried changing the temperature switch and the fuel sending unit?
I believe they could be the culprit.... if the temperature switch is bad the vehicle may experience inaccurate temperature gauge function, overheating engine, internal engine damage and/or excessive fuel consumption. About $7.00 at Auto Zone
And if the fuel sending unit is bad, the fuel gauge may not work properly, and this is a problem Ive dealt with recently. Even though I got one off my dad he had saved just in case his truck needed it, at Auto Zone about $65.00
Old Feb 21, 2011 | 07:50 PM
woodys ride
my alternator went than my dash stoped working ive replaced the dash thinking it got burnt up and that eas not the problem
JOHN2001
Oct 20, 2012 06:29 PM
tnwalker01
Jul 16, 2012 02:12 PM
briana compton
1997 - 2003 F150
Aug 28, 2011 08:32 PM
06F250XLTFX4
May 13, 2008 06:50 AM
rshields1
1997 - 2003 F150
Jan 7, 2006 08:13 AM
