4spd conversion in a highboy
Old Feb 19, 2011 | 03:17 PM
Scolesy8's Avatar
Scolesy8
i have a 77 highboy with a TCI C6, and im wanting to convert it to a NP435. i've got the trans and bellhousing for the truck, but the only things im needing now is, Clutch, Flywheel, and Pedal/Linkages. what clutch would you recommend for this application? where can i get a decent flywheel? will a 460 flywheel work? which is best, the original setup or a hydraulic? and finally, is there anyway i can find the pedal linkage set up in a package deal or not? Just some things i need to cover..... i'm running a 408 that is used mainly as a weekend truck to drive, shows, and occasional truck pull.
Old Feb 19, 2011 | 07:25 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You have a 351M/400? You'll need the 335 series (351/400) flywheel, not a later externally balanced 460 flywheel or early 429/FE flywheel.
As for linkages, pedal etc you're best bet is the junkyard and snag everything. Also get the pieces for your truck and not the 73-76 pieces as they are slightly different.
An 11.5" long style clutch will hold a tank.
Josh
Old Feb 19, 2011 | 09:36 PM
Scolesy8's Avatar
Scolesy8
ok, should i go with the factory linkage set up or do a hydraulic?
Old Feb 19, 2011 | 09:43 PM
Bullitt390's Avatar
Bullitt390
Factory linkage is straight bolt in, you'll have to beef up the firewall and fab a bracket for the bellhousing to run hydraulic.
Josh
Old Feb 19, 2011 | 10:35 PM
Scolesy8's Avatar
Scolesy8
ok. well that will probably be a little cheaper as well. any thoughts on clutch? Jeffs bronco graveyard sells a LUK clutch kit for $219. any good?
Old Feb 19, 2011 | 10:40 PM
Bullitt390's Avatar
Bullitt390
I would go Zoom, McLeod or Ram.
Most NAPA clutches are rebadged Zooms, sometimes cheaper as well. Long style will hold better than diapragm, but diaphragm for all intents and purposes is "easier" on the left leg.
I have a Zoom long style in my truck.
Josh
Old Feb 19, 2011 | 10:45 PM
Scolesy8's Avatar
Scolesy8
so in otherwords i should be checkin out napa? is there any difference between a long and diaphram that would require me to change any parts like bellhousings or stuff?
Old Feb 19, 2011 | 11:01 PM
Bullitt390's Avatar
Bullitt390
The only thing you may or may not have to do is remove the return spring on the clutch pedal for the diapragm. Some, hence the term "some" have had issues with the diaphragm being over centered and not allowing the pedal to return. Removing the spring, which seems counter productive, helps to prevent that situation.
Josh
Old Feb 19, 2011 | 11:09 PM
Scolesy8's Avatar
Scolesy8
but it only needs removed if i were to go with a long style correct?
Old Feb 19, 2011 | 11:14 PM
Bullitt390's Avatar
Bullitt390
No the factory set-up is designed with the long style in mind, when installing the diaphragm (i.e. Chevy style clutch) it is possible to iver center the diaphragm "fingers, so some guys remove the return spring to help.
Josh
Old Feb 19, 2011 | 11:16 PM
Scolesy8's Avatar
Scolesy8
ah ok ok i get it now
Old Feb 21, 2011 | 04:32 PM
Scolesy8's Avatar
Scolesy8
whats your thoughts on this clutch? from what i was told, since im not putting out some outrageous amount of power, and i still want to drive it, this would be a decent clutch for me. being able to drive it is more important to me than hauling and such.
Zoom Performance Products HP80-1A - Zoom HP Series Clutches - Overview - SummitRacing.com
Zoom HP series clutch
Old Feb 21, 2011 | 08:08 PM
Bullitt390's Avatar
Bullitt390
I would do one of these two...
Zoom Performance Products MU1011-1 - Zoom MU Series Clutches - Overview - SummitRacing.com
RAM Automotive 88777 - RAM Premium Replacement Clutch Sets - Overview - SummitRacing.com
Here is the rebadged Zoom at Napa...
Store Locator | NAPA Online
Josh
ATC Crazy
May 13, 2013 02:14 PM
tikkakoski
16
Sep 9, 2012 05:30 PM
lasthighboy
Feb 24, 2008 02:47 AM
cobraguy
Mar 14, 2001 08:20 AM
