Sponsored by: Auxito
Press/fit connection
Old Feb 19, 2011 | 09:30 AM
manderson's Avatar
manderson
I have to replace the intake manifold bypass tube on my '02 F150 4.2L. It's pressed in there. I can get the old one out but I want to make sure I install the new one correctly.This job's been a pain and I don't want to have to do this job over again.
Old Feb 19, 2011 | 12:35 PM
planehunter's Avatar
planehunter
Is there a particular question about this job? Are you sure it's a press fit?
Old Feb 20, 2011 | 11:57 AM
manderson's Avatar
manderson
Yes, I've seen the new part and it's presses on. It also has what looks like black teflon tape on the manifold end. My concern is with the confined space to work with I want to do it right the first time and not have to redo it(who does, right?). Also, I've seen connections were you have to use a torch to heat one side up to get both ends connected, I hope this isn't that type of installation.
Old Feb 20, 2011 | 02:56 PM
planehunter
The black teflon tape material will be the joint sealer, but I doubt it's tape of any kind. My guess it's a type of epoxy and the pressure fit and engine temp help seal it. If Ford doesn't list this as available, you will have to try something from Locktite. Locktite makes products that should work for this since it is basically a gap filling hydraulic type seal, and you are working at fairly low temps. Without the manifold out, it will be a tough job.
Jarryd
Mar 14, 2014 09:17 AM
eman92082
Apr 3, 2011 09:40 PM
slim pickens
Dec 31, 2008 03:56 PM
CarlF250
Mar 13, 2008 02:25 PM
DavidExp01
Sep 22, 2006 08:05 AM
