Ball Joint Press
Old Sep 21, 2006 | 10:18 PM
DavidExp01's Avatar
DavidExp01
Ball Joint Press
I'm planning on replacing the lower ball joints on my 2001 EB Exp. Does any one know if the OTC 7249 tool kit have the right sizes for the job? Or what size diameter adapter I need to press out the lower ball joint?
Old Sep 22, 2006 | 08:05 AM
gibsonj's Avatar
gibsonj
This kit from Harbor Freight has the right size cup:
http://www.harborfreight.com/cpi/cta...emnumber=46389
I use these with my shop press. Never had much luck with the C-clamp press and ball joints. But, if you can get a C-clamp press to work, then it definitely saves some work since you won't have to remove the lower control arm.
Advance and Autozone have tool loaner programs, so you might be able to borrow what you need if you don't want to invest in your own tools.
scsprop
Sep 18, 2014 09:22 PM
boosteddsm
Jun 15, 2011 09:44 PM
CarlF250
Mar 13, 2008 02:25 PM
jwcnj45
Mar 21, 2005 09:48 PM
