When Diesel is way over $5 a gallon do Truckers sleep all day in the truck in 100 degree heat
an the Diesel running
Are the Refrig trailers a better option?
almost all big rigs these days have an APU mounted to the frame to provide electricity instead of running the engine. typical APU is around 5,000 watts, and uses less than 1/4 gallon of diesel per hour compared to about 1 gallon per hour running the engine.
^^^^OMG why is that groan button not yet an available emojy here?
I could and would gladly get right behind her all the way!
Very true, found most often in the OTR rigs---these have been an absolute great idea for big trucks not only in fuel savings but reduced wear and tear on the uber-expensive main engines too.
