351 aod transfercase
Old Mar 12, 2003 | 10:26 AM
superhooperduty's Avatar
superhooperduty
I'm(hopefully) installing a 351 windsor from a 88 truck in my 91 f150 4x4, I want to use a aod tranny, from a 82 truck, will it bolt up to my transfer case? from the pictures I've seen it looks like I have a bw 1345. I want to get rid of the 302 and e40d and go with a carburated engine. I guess if I can't use the same transfer case I'll try to add a few goddies to the 302, but I've added underdrive pulleys, mac shorty headers and k&n filter and flow master cat back exhaust and I don't notice any improvement at all, dang it anyway, I need some more pulling power
Old Mar 12, 2003 | 10:55 PM
steve83's Avatar
steve83
All 80-96 fullsize 1/2-ton t-cases bolt up to all 80-96 1/2-ton 4WD transmissions.
Sell the pulleys.
Old Mar 12, 2003 | 11:29 PM
superhooperduty
Thumbs up 351 aod transfercase
thanks for the info, i'll admit it had me a little worried, too cold here right now to slide under and drop the t case to check, thanks again
Old Mar 22, 2003 | 07:14 AM
MikeZealot's Avatar
MikeZealot
I was given information by a transmission remanufacturer that the output shaft for the E4OD 4WD is much larger than the output shaft for the AOD 4WD, therfore the AOD wont mate to the BW1356. in place of the E4OD........
: ( ruined my plans ......
mike
Old Mar 22, 2003 | 11:51 AM
steve83's Avatar
steve83
He was wrong. You could have done it with no problem. I've had a 1356 from an AOD sitting in my junkpile right beside one from an E4OD, and they're identical (at the mounting surface). You can see them here.
Old Mar 22, 2003 | 04:50 PM
superhooperduty
the info i have tells me that i have a bw 1345 t case. is that gonna make a difference?
chadww87
Offroad & 4x4
Jan 21, 2014 09:05 PM
granny_rocket
Mar 17, 2012 11:28 PM
xxclaro
Sep 25, 2010 04:58 AM
Spktyr
May 14, 2004 11:26 AM
superhooperduty
Mar 25, 2003 10:29 PM
