cant remember...
Old Feb 17, 2011 | 11:54 PM
chicagodragon's Avatar
chicagodragon
cant remember...
i ve seen this before, but cant remember the cause. headlights come on, but not the running or dash lights. playing with the switch gets the running and dash lights on, but not the headlights. i remember it being something simple, but not the switch. or am i wrong and it is the switch?
Old Feb 18, 2011 | 07:57 AM
Action4478's Avatar
Action4478
If you have a tilt wheel , it may be a broken wire in the column leading to the MFS..
Old Feb 18, 2011 | 01:12 PM
chicagodragon
of corse i got outside to look at it and all is fine. i tilted the wheel from one end to the other, turned the headlight switch off and on a hundred times, turned the wheel etc... not a blink. is there something iam missing like a relay.
Old Feb 18, 2011 | 06:38 PM
fordpride's Avatar
fordpride
is the switch still in the other dash you got? If you have it i would try swaping them and see what happens
Old Feb 18, 2011 | 06:47 PM
RRranch's Avatar
RRranch
get your gun and look under the seat for gremlins. I HATE it when this stuff happens.
Do you have a bunch of gauges in the truck by any chance on a pillar pod? I ran one of the screws holding it on once through the hot wire to the clearance lights. It shorted all of the running and dash lights.
Not sure if that helps.
Old Feb 18, 2011 | 07:04 PM
chicagodragon
i do plan on replacing the switch just to be safe, the switch that came with the 92 was definitly bad. i gaurrentee if i leave a bar at night.itll act up
no pillar pod and my roof lights are factory run on the passenger side. i still wanna look for a short and see if maybe it is a breaker resetting, i do have alot of lights
Old Feb 18, 2011 | 07:21 PM
Action4478's Avatar
Action4478
The main light switch (IIRC) has a breaker in it , a short will usually make it flash ...A break in a wire can be yup or nope...
chicagodragon
i just went back out and messed with it again. actimg up! the only thing that seems to make a difference is playing with the switch. i dont think that our trucks have any lighting relays, do they? does all the power run through the light switch. it seems like the running light contacts are burned. when i swap it out, ill open it and let yall know what i see.
Old Feb 18, 2011 | 07:23 PM
chicagodragon
its only the running lights giving an issue. headlights seem to be fine. just now when i tried it, everything was cold/ first time lights on today
Old Feb 18, 2011 | 07:51 PM
rodneywar's Avatar
rodneywar
sounds like the contacts are bad same problems for mine as well. i have a spare one that i am putting in to fix that problem. also why not do the headlight mod while you are at it
newfordy
1997 - 2003 F150
Nov 9, 2014 06:29 AM
whiteisright
Apr 27, 2012 08:31 AM
TAT2DUP81
Feb 24, 2011 12:22 PM
TNT in Round Rock
Aug 9, 2007 08:39 AM
Mike McKown
1983 - 2012 Ranger & B-Series
Feb 6, 2007 10:30 AM
