Replacing the radiator support
Old Feb 17, 2011 | 04:19 PM
ragphoto's Avatar
ragphoto
What is involved replacing the radiator support. At first glance it seems pretty easy and straight forward. Any suggestions?
Old Feb 17, 2011 | 05:22 PM
GreenDinosaur's Avatar
GreenDinosaur
Well you have to remove the following to do it:
1 front bumper
2 rock gaurd ( part just behind bumper)
3 grill shell and hood latch
4 both fenders
After those are out of the way then you can remove the radiator support, however you may want to remove the hood to reduce the weight on the inner fenders cuz the inner fenders are bolted to the support. That's how I did it.
Old Feb 17, 2011 | 05:32 PM
ragphoto's Avatar
ragphoto
Thanks, That's what I figured, good heads up on removing the hood. Do you think that is totally necessary is the hood really too much weight?
Old Feb 17, 2011 | 05:56 PM
GreenDinosaur
It might not be too much, I took my hood off cuz I had to repair and paint my inner fenders. I'd just be careful if ya leave the hood on just in case.
Old Feb 17, 2011 | 08:33 PM
ragphoto's Avatar
ragphoto
cool thanks
Old Feb 17, 2011 | 08:39 PM
GreenDinosaur
No problem, Have fun
Old Feb 18, 2011 | 10:42 AM
orich's Avatar
orich
I had no problem leaving the hood on. I did remove the battery thou.
I used a 1975 in my 71 and had to make a couple new holes for the hood latch which is ez to do with a dremel cut wheel if you can't find the same yr support replacement part. You'll need a drill some small holes make them square latch bolts. There is a difference in radiator size openings with engine size so get the one for your size of engine. But the smaller opening can be cut wider for your radiator size if you get the wrong one..my 2cents
orich
MADE CENTER HOLE
<a href="http://1971ford4x4.multiply.com/photos/album/1/Old_blue#49"><img border="0" src="http://multiply.com/mu/richm512th/image/2:1971ford4x4/photos/1/500x500/49/dsc-035.jpg?et=FoEE9FmlxHAlO8aIJQn%2CpQ&nmid=124639485 "></a>
Old Feb 18, 2011 | 10:52 AM
GreenDinosaur
+1 on removing the battery, also another tip, there are bolts at the top outer ends of the grill shell that I had to use a universal joint on the end of a long extension for the ratchet, cant get a wrench in there.
forthvacav
Jul 13, 2016 07:55 AM
barryf
Oct 11, 2011 07:27 PM
xc4jokestomper
Jul 16, 2011 10:17 PM
nick5050
Jul 7, 2011 11:38 PM
eddiey
Apr 21, 2009 01:05 AM
