Pull the front clip, 45 min max and help with the opp side when ready. Much easier, and no reason to pull the engine for the most part. But it will be much easier if you just have to. Would suggest pulling clip and then engine trans together so no seals/alignment etc issues getting it back together. Could easily end up costing more than expected.
Pulled the 64's and seems it was only the main 2 bolts up front on frame, wire harness, 2 under fwd cab and one or two each side inside door ..there is a thread on it here somewhere. Way easy and no reason to pull engine.
Link: https://www.ford-trucks.com/forums/8...p-removal.html
