turbo
Old Feb 17, 2011 | 06:28 AM
1bad04's Avatar
1bad04
turbo
Hi eveyrone, I have a question about my turbo on my 04 6.0l 4x4. How long does it take before you start to hear your turbo at first start up? I think I may have a prob because im not hearing it until truck goes into high idle and still the turbo sounds muffled... Thanks for any info. Mark,
Old Feb 17, 2011 | 10:29 AM
smokersteve's Avatar
smokersteve
With in 4 seconds at its coldest. How many miles?
Old Feb 17, 2011 | 01:17 PM
1bad04's Avatar
1bad04
127,000 miles and got a PO472 code today.
Old Feb 17, 2011 | 01:41 PM
smokersteve
From a stop, is it slow to spool up?
If you go to WOT and take your foot off at 5mph will it bark, turbo fart?
Old Feb 17, 2011 | 02:09 PM
dchamberlain's Avatar
dchamberlain
I very rarely hear my turbo. Only when I really start to get into it. Or don't get the passenger side door closed. And even then I've never heard it at idle.
I would check the EBP tube for restriction on the P0472 code. And then like Steve said, see how well the turbo works while driving. If it's slow to make boost, or overboosts, there might be a problem.
Old Feb 17, 2011 | 02:27 PM
smokersteve
I think it comes off the drivers side manifold.
On a different thought. Would it be better to connect that sensor to the y-pipe? I feel that it would give a better and much more consistent reading.
Old Feb 17, 2011 | 02:36 PM
dchamberlain
I don't think it would be a good idea to change the place where the EBP tube connects. You may get a more accurate reading, but it may not be what the computer expects and unforeseen things may happen.
Old Feb 17, 2011 | 03:03 PM
broncoformudv's Avatar
broncoformudv
Its good to know I am not the only one that doesn't hear their turbo. I have heard other 6.0ls turbos when they have been around me and often wondered why I do not hear mine. Mine is the only 6.0l I have ever driven so maybe I need to go for a ride or drive another one just to see how mine is performing?
Old Feb 17, 2011 | 03:25 PM
dchamberlain
The turbo sound is a lot more noticeable from the outside of the truck. That's why I can hear mine when the passenger door isn't fully closed. The trucks insulation is blocking the sound. It'll also sound louder if you've deleted the cat and/or the muffler. I've also heard that '03 turbo's are louder.
Old Feb 17, 2011 | 04:57 PM
broncoformudv
I have heard that about the 03 turbo as well.
My exhaust is stock and I have listened from inside and outside my truck with no difference.
Old Feb 17, 2011 | 05:01 PM
1bad04's Avatar
1bad04
Yes it does seem to be taking longer to spool. Also do get some turbo farting from WOT but if thought I heard here that was kinda normal?
Old Feb 17, 2011 | 05:07 PM
smokersteve
on a fully stock truck you should not have any tubo barking.
1bad04's Avatar
1bad04
Just got in from a test drive after cleaning EBP tube and installing brand new EBP Sensor, No Differance I can say my turbo has been alot loader in the past and performance is down. But on another note over the weekend I installed the blue Fuel spring upgrade and cant say that the truck has performed that well ever since.
rblyll
Apr 23, 2009 01:25 PM
indyraven
May 7, 2008 07:52 AM
mangopuppy
Apr 22, 2008 09:24 PM
deanroller
Feb 20, 2006 10:08 PM
My4x4Toy
Jan 2, 2004 08:09 AM
