Backup Camera
Old Feb 16, 2011 | 09:47 PM
ThomasP's Avatar
ThomasP
Backup Camera
I've just purchased an 06 Explorer with a navigation system. Is it possible to install a backup camera and view it through the navigation system? Also is it normal for the transmission to drop out of OD real easily with the cruse control engaged but holds OD when right footing it?
This is my first post so be gentile.
Old Feb 16, 2011 | 09:54 PM
vipersinu2's Avatar
vipersinu2
I used coastal lock pick
2007 mercury mountaineer
watching movie from ipod
view of the back up camera
night vision camera,
inside the tailgate this is the grommet for license plate lights,
this is a picture of where all the clips are located on the rear gate trim panel
i fished the headliner to the front a pilar
inside truck there is a conduit for the wiring.
going into the tail gate, tight fit grease wires before pulling!
reverse wire at driver side kick panel
nexted thing will be headrest lcd dvd monitors, does anybody have suggestions on what brand or size to get?
Old Feb 16, 2011 | 10:16 PM
ThomasP's Avatar
ThomasP
What is costal lock pick? Where did you connect the camera on the Navigation system?
Old Feb 16, 2011 | 10:21 PM
vipersinu2's Avatar
vipersinu2
click this link it has all the information
FORD 360 LOCKPICK
Old May 22, 2011 | 07:02 AM
vipersinu2's Avatar
vipersinu2
2007 Ford Mountaineer backup camera Coastal Lock Pick
YouTube - ‪2007 Ford Mountaineer backup camera Coastal Lock Pick‬‏
Great instruction video from the guys at coastal lock tech lock pick.
Easy install worked for me on the first try. I did not have rear dvd entertainment, (my radio now say rear entertainment enabled but no sound comes from that input) so to hear the sound from the input of the lock pick, I had to set the radio to the Sat input. so if you do not have the sat radio you might want to talk to the guys at coastal tech to get the inputs all correct for the sound.
also there is a slight loss of picture quality now on the radio screen. but in the end it is worth it.
VaSheriff
Dec 18, 2019 03:58 PM
Lilyhy
2014+ Transit
Apr 13, 2016 07:19 AM
Hossfly05
Mar 23, 2016 10:43 AM
ncgun99
Feb 21, 2016 09:22 PM
racin
1997 - 2003 F150
Dec 26, 2015 10:25 PM
