I've just purchased an 06 Explorer with a navigation system. Is it possible to install a backup camera and view it through the navigation system? Also is it normal for the transmission to drop out of OD real easily with the cruse control engaged but holds OD when right footing it?
This is my first post so be gentile.
2007 mercury mountaineer
watching movie from ipod
view of the back up camera
night vision camera,
inside the tailgate this is the grommet for license plate lights,
this is a picture of where all the clips are located on the rear gate trim panel
i fished the headliner to the front a pilar
inside truck there is a conduit for the wiring.
going into the tail gate, tight fit grease wires before pulling!
reverse wire at driver side kick panel
nexted thing will be headrest lcd dvd monitors, does anybody have suggestions on what brand or size to get?
Great instruction video from the guys at coastal lock tech lock pick.
Easy install worked for me on the first try. I did not have rear dvd entertainment, (my radio now say rear entertainment enabled but no sound comes from that input) so to hear the sound from the input of the lock pick, I had to set the radio to the Sat input. so if you do not have the sat radio you might want to talk to the guys at coastal tech to get the inputs all correct for the sound.
also there is a slight loss of picture quality now on the radio screen. but in the end it is worth it.
