The TTB Thread
Like a lot of guys, my '84 is still running a TTB setup. I've searched and read till my head was spinning and this is some of the info I gathered. Some of the info is repeated within other threads, but it's all worth reading. Some links pertain to Rangers and BII's, but the meat of the info still applies to our full size rigs. This is good reading for those wishing to understand and tweak their TTB setups. So without further ado, here are my links.
Spicer Dana 44 TTB Service Manual - Dana 44 TTB Service Manual (PDF File)
Spicer Dana 50 TTB Service Manual - Dana 50 TTB Service Manual (PDF File)
Ford's (In)Famous TTB Suspension
TTB vs. The World
Dana 44 TTB Axles
School me on TTB axle set-ups
Getting the most out of your Ford TTB Suspension
Lifting a TTB Suspension
Lift and Tire Information for 80-96 Bronco
Dana 50 3rd member and stub shaft install - upgrade your D44 stub shaft and inner u-joint
D50 Inner Upgrade
Drain plug install on TTB front axle
My Gear and Locker Install (pics) - Front axle install starts on page 3
Dana 44 8-lug swap - Chevy conversion
Steering Tech - An in-depth discussion about TTB steering and alignment
Maximizing Your Wheel (Suspension) Travel
D44 TTB TRE Flip
TTB Uniball
Extended Radius Arms
Extended Radius Arms - more discussion
Longer Suspension Travel
Limits of long travel Dana 44 TTB
Questions on Long-Travel TTB
Random TTB Pics - some nice pics within the thread
TTB Flex Thread
Let's have a review/comparo of Ford coils springs - Coil info for TTB setups
ORA Ford Heavies 1980-86 - Suspension and tire info for 3/4 and 1 ton TTB, good general TTB info
Dana 44 IFS Limited Slip Confusion - FSB Forums - C-Clip Eliminator (external spring)
Let's See Custom TTB Setups - Good info
Superflex TTB - Convert TTB to run 78/79 coils (softer spring rate than TTB coils)
Coil Spring for TTB Flex
Softer Spring for TTB? - Some good coil spring info in here
F-250 Shock Tower Mod - Run longer shocks on your TTB, Ranger link but applies to our trucks.
D44 TTB and D44 solid HP parts compatibility??
Some basic info for those who need it:
<embed src="http://www.youtube.com/v/vTyS9unPx2A?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="390">
TTB suspensions in action:
<embed src="http://www.youtube.com/v/s7IMMY-EgVg?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="390">
<embed src="http://www.youtube.com/v/xyZj5kPObDE?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="390">
<embed src="http://www.youtube.com/v/7SiJrQ0b7Jo?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="390">
<embed src="http://www.youtube.com/v/P8VD0d3ZqT0?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="390">
I didn't get all my links posted, but this should make for some good reading for now. Updated as I find links of interest.
I sure don't hate my TTB D44 HD under my Diesel truck, it's got 377k miles on it, and never had a problem with it. Sure did go through alot of Ball joints though.
SI Motorsports, Inc. - Performance Pre-Runners, Long Travel Suspension and Custom Fabrication
Glovemeister, there was a guy in Corvallis parting a 85 F350 crew cab that had a 4" Rough Country kit on it; guy said he'd take $300 for everything; front leaf springs, drop brackets, drop pitman arm, blocks for the rear, U-bolts, etc. His contact info is at Enviofuel.com
