FRONT U-JOINT REPLACEMENT
Old Feb 17, 2011 | 11:59 AM
  #31
rn360908's Avatar
rn360908
Originally Posted by f350rebel7788
ok guys put the tape measure away. if it works without damage go with it. everyone has their own preference and it dont matter as long as the job gets done the same way. and for the record, i used a magazine around the spindle AND a screwdriver to pry it off after it broke free. now back to the original topic, as far as the ujoint, a small socket and hammer should just pop it out right?
The axle shaft should pull right through the hole in the knuckle without a problem, shouldn't need a hammer.
If you’re working on removing the ujoints from the axle shaft you will more than likely need more than a small hammer and socket. You need to first remove the retaining clips. Then once you do that you will want to place your axle shaft in a vice and open the vice up till two of the four yoke ears are resting on the vice. Then you’re going to smack the axle shaft where I have the arrow placed and in that direction. The other line in the picture is a reference line and and runs the length of the axle shaft in the center.
I know this is a pic of a driveshaft, but this way also works on axle shafts.
You will continue to hit in that spot till the cap located nearest to where you’re hitting comes out and you will repeat this three more times to knock the other 3 ujoint caps out. This doesn't require alot of force even with the most seized up ujoint cap. The most important thing not to do is case deformation of the round hole where the cap goes, this is usually caused by missing your target of where you want to hit or getting to close to the hole while hitting. I know there are a 1000 ways to do this but I find this to be the easiest for me.
Old Feb 17, 2011 | 12:25 PM
  #32
pjwoolw's Avatar
pjwoolw
OP do yourself a favor and take the axle to a machine shop and have them do the R&R of the u joint. If you don't have a vise large enough or ball joint press beating it out and in with hammer is going to guarantee you'll be doing it again soon.
Old Feb 17, 2011 | 12:28 PM
  #33
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
Okay, clips are off, but all the beating in the world isnt getting the caps to move more than an eighth of an inch... Any suggestions?
Old Feb 17, 2011 | 12:34 PM
  #34
rn360908's Avatar
rn360908
I know an 1/8" isn't much but try getting ahold of the cap with the vice and rotate the axleshaft back and fourth while pulling the axleshaft up and away from the cap, it usually works but i have never had one start coming apart and then stop at 1/8"
Old Feb 17, 2011 | 12:39 PM
  #35
pjwoolw's Avatar
pjwoolw
Why don't you two take this to PM's. Reading this is making me cringe. Unsubscribing
  #36
stubborn66's Avatar
stubborn66
It is a few minute procedure for a shop with experience. It should cost about $20.00 to change the joint on the axle.
A press is the best way to do this but if you dont have a press you need to use the beat and poud method. if you still want to do this part of the repair yourself you do need to be careful that you do not bend the end of the shaft otherwise you will not get the new joint installed or teh clips back on if you do get the cups in.
Old Feb 17, 2011 | 12:57 PM
  #37
Neal 97 250's Avatar
Neal 97 250
Do you have a vise?
If so I here is a method that works fgood for me.
Take a socket that is about the same size as the cap but just a tad smaller, so it will push the cap thru without getting stuck.
Then get another socket that is just a bit bigger internally than the cap. Put the small socket on one cap, put the bigger socket on the axle over the cap just oposite. Put that setup in a vise and squeeze it together. It will push the whole joint thru and you will be able to get a hold of the cap that is going into the bigger socket wit a oair of vise grips or even a vise as mentioned earlier.
Sorry I had to bail on you yesterday. But man I am glad I missed all that other garbage that went on.
Be sure to keep the whole setup lubricated with PB blaster or similiar penetrating spray. Remember penetrating spray will work into there with a little vibration from a hammer. Don't beat the S*%t out of it though. LOL
Good Luck.
Old Feb 17, 2011 | 01:30 PM
  #38
f350rebel7788
yeah, i don't have a vise big enough, but i've been drenching it with Rem oil (i know it's gun spray, but it works just as good as anything i've used before) and now it seems to be breaking free with a little bit of force and determination thanks for all the help guys! if i run into any more problems, i'll let you know!
Old Feb 17, 2011 | 01:50 PM
  #39
Neal 97 250
If you get one of the caps to just stick out a little bit you can put a pair of vise grips on it and twist till it comes out.
Then flip and repeat.
Sounds like you are on your way. Good luck.
zottyzot
Nov 7, 2010 06:32 PM
SHOpar
Jun 21, 2009 10:32 AM
MontanaMan
Apr 27, 2009 08:03 AM
tietje_3
Oct 13, 2006 08:32 PM
trixie
Apr 27, 2002 12:24 PM
