Left front turn signal light dead
2000 F250 diesel 2 wheel drive short bed 184k miles
left front turn signal has now power, replaced bulb still dead, tried second new bulb still dead
left turn indicator in dash also dead
left rear flashes very fast with left front dead
parking lights all ok so doesn't seem like ground- are there two grounds?
4 way flashers all work normal except front left light
fuse ok
flasher seems ok as right signals both work normal as well as dash indicator
put test light on left front socket with bulb out- no power to signal light
left front signals all worked ok at night going home from work- had to travel on rough roads due to construction- didn't work next morning
could I have broken wire from light to dash?
have Haynes manual and it shows a LT GRN/WHITE wire going to left front turn lamp plus dash signal indicator- is this hard to trace under the truck?
not sure how the wiring is routed below truck
can take wheel off truck this weekend to trace
any ideas??
thks
Terry
fuse ok
any ideas??
thks
Terry
52' fordnut
07-21-2015 10:07 PM
r0cker
01-09-2014 03:34 PM
SparkyRnD
04-06-2011 12:16 AM
