help with u haul ip's
Old Feb 15, 2011 | 09:09 PM
fordhorse's Avatar
fordhorse
im looking at u haul ip's they have 0ne for 94e350s for 260 and one for 89-90f350s for 220 is the 94 a turbo pump with the torque screw im looking to get one asap but i want one with the screw cuse my truck is a turbo hopeing someone can help me thaks
Old Feb 15, 2011 | 09:10 PM
wreckinball's Avatar
wreckinball
92.5 and up all have the torque screw. hope that helps!
Old Feb 15, 2011 | 09:12 PM
fordhorse's Avatar
fordhorse
thanks so i guess i want the 94 then
Old Feb 15, 2011 | 09:13 PM
LCAM-01XA's Avatar
LCAM-01XA
The $220 pump will not have the torque screw, I just put one such pump in my truck. The E350 pump will most likely have the screw. Before making a decision on which pump to get, make sure you find and read and understand Dave Sponaugle's explanation of how the torque screw works.
Old Feb 15, 2011 | 09:34 PM
Coalroller's Avatar
Coalroller
my question is... is the torque screw really that important?
Old Feb 15, 2011 | 09:46 PM
wreckinball
only if you have a turbo, it can help a lot with spooling faster and take off. otherwise it melts pistons and makes a lot of black smoke! lol
Old Feb 15, 2011 | 09:55 PM
fordhorse's Avatar
fordhorse
mine has a turbo and that's why i wanted one with the screw that would help with takeoff pulling my horde trailer and i got a boost and pyro im also looking for injectors has anyone ever got them from Pensacola diesel bb code are the best ones right
Old Feb 15, 2011 | 10:12 PM
wreckinball
i believe the pensacola ones are okay and yes go with the BB codes. if you want a matched set get the ones from russ/type4 or similar.
Old Feb 15, 2011 | 10:34 PM
fordhorse's Avatar
fordhorse
thanks everyone for the help
Old Feb 16, 2011 | 03:16 AM
91dirtydiesel's Avatar
91dirtydiesel
I just put in my injectors from Pensacola. Very pleased so far. I also put the u-haul ip in. Still working on getting it perfect. Ran into a bunch of leaks at the injector connections and it was a real problem gettin the new ip and injectors started since there were dry.
Old Feb 16, 2011 | 09:35 AM
wreckinball
yeah bro i was hoping everyone read my pain in my post. I even have the electric pump and still took forever. Keep all of the lines completely cracked until it leaks at the injectors then tighten all of them up and should be fine. I would think priming the pump ahead of time possibly through the fuel screw plate maybe? Definitely a chore haha
Old Feb 16, 2011 | 03:00 PM
ghunt's Avatar
ghunt
I don't think the torque screw does crap, I've messed with mine and never seen any difference in anything.
Old Feb 16, 2011 | 03:17 PM
LCAM-01XA's Avatar
LCAM-01XA
Lol, so your e-pump didn't do much of anything to prime the empty IP? Hey Ford250XLTwhatever (man you got a looong username), ya hear that? lol
Mine took a bit of cranking to get her primed too, but it proved that good batteries don't care for that - least mine didn't, I started at 12.5V and coutless 10-second crank cycles later they were still at 11.8V or so, during the last three 10-second glow and crank cycles that finally got the thing fired up the lowest voltage I saw was in the high 10s...
Old Feb 16, 2011 | 04:09 PM
wreckinball
yeah when they air lock, they air lock. I had positive pressure at the injectors so it hissed when i cracked the lines haha.
ghunt,
how old is your pump? How much did you adjust it?
Old Feb 16, 2011 | 04:51 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
it should prime a totally empty ip shouldn't it?
it's an open fuel system,so if you were to turn on an e-pump and just let it push fuel for lets say,5 minutes (might not take that long,but why rush it?) shouldn't it just push all the air right out into the fuel tank.
how long did you give it wreck? maybe you where just too exited to wait long enough lol.
pushing fuel using an electric pump or using the starter to rotate the engine/stock lift pump = same results after all.just a different way of pumping it.so if i where to change an ip,id likely just wait for the e-pump to fill and purge the system for many minutes if need be.but iv never done it yet personally.just what id try first.heck they only draw 2 amps.i might have just gave her 10 minutes purging the system.nothing to loose.
