Just curious as to what everyones transmission temperature is? I have a trans temp gauge in my truck but not sure if it is working correctly so wanted to see what yalls gauges are reading
Seems to be about 60 degrees over ambient temp. However I also have a TruCool supplemental cooler. The stock system might be around 80 degrees over ambient.
You will most likely not see it move (depending on location). Mine will run at 130* on the freeway all day long with a 6.0 Trans cooler. When I tow I see 160-180*.
ok that makes me feel a little better about it because it wont always register but when it does it might hop up to 150* all the way to 170* just driving around town, i.e. i was driving approx 30 mins today and next thing i knew the gauge was reading 170* and wasnt reading anything a few minutes before so im not sure if its reading accurately. however, ive made 9 hr road trips before and the needle would never move. thinking i might have to change it soon and find one that starts to register at 100* to make sure its working. what do yall think? and i live in louisiana so temp shouldnt keep my temps that low (i wouldnt think anyway, could be wrong)
