Code Reader/Scanner, Quick Question
Old Feb 14, 2011 | 07:21 PM
Risk176's Avatar
Risk176
I am looking at buying a code reader for my PSD. What are the benefits to having one that reads live PCM data? Thanks in advance?
Old Feb 14, 2011 | 07:30 PM
pjnadon's Avatar
pjnadon
The best one in my opinion is A/E AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
Old Feb 14, 2011 | 08:16 PM
tex25025's Avatar
tex25025
I second that, but make sure you get at least the Ford Enhancement license in order for you to be able to read our trucks. Otherwise without it, you'll only be able to get the generic powertrain info.
Old Feb 14, 2011 | 08:48 PM
Risk176's Avatar
Risk176
I know about the AE but was thinking of something "smaller" like this.
New MS509 OBD2 Scanner Code Reader Live Data cable OBD2 - eBay (item 280608997222 end time Feb-26-11 01:27:25 PST)
Old Feb 14, 2011 | 09:13 PM
John Irwin's Avatar
John Irwin
Something is not quite right there. I don't see a plug that would fit the obd2 test port, maybe I'm missing something. That device sure does a lot of things for a 60 dollar scanner. I'm thinking it's just part of a package?? My AE cost 360 bucks and needs a laptop to use it. My spidey senses are tingling on this one, maybe I'm wrong.
Old Feb 14, 2011 | 09:15 PM
John Irwin's Avatar
John Irwin
It's weird...sometimes I see an interface at the very bottom of the screen, and then there's nothing...
Old Feb 14, 2011 | 09:36 PM
tex25025's Avatar
tex25025
3rd picture, the one with just the wires, I do believe that it has the OBD cable.
The biggest thing I would worry about is can it read CAN.
Old Feb 14, 2011 | 09:53 PM
pjnadon's Avatar
pjnadon
Originally Posted by Risk176
Those readers can only give some generic codes if your lucky because our trucks are not required to be obd compliant the cheap readers can't pull codes
Old Feb 14, 2011 | 10:01 PM
Risk176's Avatar
Risk176
So then what does everyone else use. I'm sure they are not all out buying the AE Software? On a side note/question, Are there situations where there are codes but no CEL?
Old Feb 14, 2011 | 10:13 PM
pjnadon's Avatar
pjnadon
Yes I have seen codes without CEL on for example if you disconect a sensor it will give you a DTC without a CEL I am not sure what else there is available.
Old Feb 14, 2011 | 10:39 PM
John Irwin's Avatar
John Irwin
I'm just starting to learn this stuff, but there can be codes present with no CEL. Anything that isn't obd2or something like that? Maybe if it doesn't produce smog it doesn't light up the CEL? I'm asking more questions than I'm answering, but what the heck, we can all learn together.
Old Feb 14, 2011 | 11:07 PM
tex25025's Avatar
tex25025
You can have a code and no light. That's why having a good code reader is paramount. Even if you just use the AE for code reading it wouldn't take long to recoup considering most dealerships charge a 100 a pop to just read codes.
Old Feb 14, 2011 | 11:36 PM
Risk176's Avatar
Risk176
Well, after what happened tonight after I posted this question about code readers, (see recent post on...no throttle!!!???) I might just fork out the cash and buy AE.
Old Feb 15, 2011 | 05:44 PM
pjnadon's Avatar
pjnadon
I would its well worth the money if you can do the work yourself Just last week it paid for its self because I had the truck at the dealership for end of warranty work and they told me my fan clutch was shot I tested it with AE and there is nothing wrong with the fan thats $570 the dealr not getting from me
captinphill
1978 - 1996 Big Bronco
Dec 15, 2015 02:26 PM
Zebo*
Computer Chips & Tuners
Sep 27, 2012 10:10 AM
KCMAGERS
May 8, 2007 12:36 AM
Finally
Feb 22, 2005 08:29 PM
Quantrex
Sep 2, 2002 06:53 PM
