wet oil pan
Old Feb 14, 2011 | 03:53 PM
FSUBOB's Avatar
FSUBOB
wet oil pan
v-10 gas 225K miles... Been smelling oil for a while now and crawled under to take a look... entire oil pan is wet with oil... its not enough to drip on my drive but it appears to be a slow seep... could it be my oil pan gasket or could a rear main cause oil to wet the entire pan? the wetness is all the way up to the block. The rear is really wet...
I am going to degrease everything this weekend and see if I can tell exactly where its coming from.
Old Feb 14, 2011 | 04:59 PM
tdappleman's Avatar
tdappleman
Could be the rear main - but that typically wouldn't cause the entire pan to get wet. Could be as simple as a pan gasket. Once you clean it you'll definitely be able to see it. Have you been able to track the overall loss and how fast you are losing it?
Old Feb 14, 2011 | 06:32 PM
labman1014's Avatar
labman1014
I thought mine was the pan also but ended up being the oil cooler where it meets the block right behind the power steering pump. As u drive the wind blows it everywhere!!!
Old Feb 14, 2011 | 06:35 PM
Stewart_H's Avatar
Stewart_H
Are you valve covers loose? One or both might be loose near the back, allowing the oil to seep out.
Stewart
Old Feb 15, 2011 | 07:21 AM
FSUBOB's Avatar
FSUBOB
wow... there are alot of places to look now!
I don't see any oil on the valve covers... I will check the oil cooler tonight and let you know.
I have only had the truck for a few months and only driven maybe 1000 miles... oil amount not noticeable on dipstick yet but it definitely smells...
Thanks!
Bobby
Gary A.
Jul 20, 2014 09:19 PM
06sonicsport4x4
1997 - 2003 F150
Aug 2, 2010 06:11 PM
powerstroke1869
22
Mar 5, 2008 05:55 PM
ajf99ford
Dec 30, 2007 10:19 AM
00GT
Escape & Escape Hybrid
May 22, 2006 06:56 PM
