I will defer to "The Man" to give you the full skinny on his pumps, but Stewart gave a good answer. I'm sure that you will be COMPLETELY satisfied with the T-.5
The graphs I posted earlier where the duty cycle goes up and the PSI is flat lined is from my stock pump. The other is from the T-1.
Stewart covered it pretty good. The T.5 is a 15 degree pump that has been converted to a 17 degree and moded. Similiar to a moded 17, but I have two small upgrades done that the standard moded 17's do not have(because of the new machined parts, I'm able to upgrade). Without going into too much detail, IMO the T.5 maybe a little more reliable then the standard 17(stock or otherwise).
I really need some name suggestions for the T.5. If you guys have some cool suggestions, don't be shy.
The T1 is a heavily modified single pump with the stock housing. I will not release it until I feel that it's longevity is proven. So lets hope Jeff can rack on several thousand more miles ASAP. Once it hit's 20-25K, I'll take it apart and measure the tolerances. Or, I'll have Jeff data log it and we'll compare to the early data gathered. If the duty cycle is the same, then I'll know we're in good shape.
hmmm, pre terminator days, t.5 = rambo, hmmm, What were all the Bronson movies in the 70's, or something from teh eastwood movies, like spaghetti westerns even, options, options.... Sudden Impact, im so tired I am not feeling witty enough tonight, maybe in the morning
