1978 - 1996 Big Bronco
Need help, Steering Box
Old Feb 14, 2011 | 10:33 AM
Encho's Avatar
Encho
The Southernmost Mod
Exclamation Need help, Steering Box
Well, this weekend the Bronco decided to give me my Valentine's in advance, so the steering box decided to explode internally (just assuming), it basically started to leak steering fluid down the linkage from the pitman arm and the steering box (i already watched very closely, the leak is coming exactly from that spot). Well, that is the issue, now, what can be done? i'll surely have to take down the box, how is it done? any recommendations? comments?.
Old Feb 14, 2011 | 10:55 AM
AbandonedBronco's Avatar
AbandonedBronco
If its just leaking fluid (and there isn't lots of slop and such), you can get a rebuild kit. My brother removed and rebuilt his in a weekend for about $80. I think he said the most difficult part was getting the pitman arm off.
The rebuild kit contains lots of seals for the fluids.
If its full of slop, you'll most likely just need to get a replacement, since that deals with worn internal gears and such.
Old Feb 14, 2011 | 11:15 AM
Encho's Avatar
Encho
I think it's just the seals, as the steering felt tight enough, i'll look into it, if not, i'll try to find a Red-Head unit, thx Abandoned.
Old Feb 14, 2011 | 11:18 AM
LCAM-01XA's Avatar
LCAM-01XA
4x4.forensick.net: '88 bronco: steering box rebuild
Old Feb 14, 2011 | 11:20 AM
AbandonedBronco
The red-head unit is the one I'll be going with. Mine doesn't leak, but it's slop-city.
Best of luck.
Old Feb 14, 2011 | 01:10 PM
greystreak92's Avatar
greystreak92
Sector shaft seal failure is not uncommon. I had one on my 92 that did it perpetually and I replaced the seals twice. (I honestly think the shaft had some wear that made the seals too thin to seal properly anymore). Unfortunately, I never got to deal with that issue any further before she was burned.
Old Feb 18, 2011 | 07:18 PM
Encho's Avatar
Encho
UPDATE: Since money is tight ATM i decided to purchase a rebuild Kit, it actually came real cheap at about $11, it also had one of the funniest disclaimers i have ever read: "NOT ALL PARTS ARE OF U.S.A. ORIGIN"... well... i guess i'll have to try my luck with this one, i hope i don't have too much trouble taking the box down. Will be trying to do the whole thing tomorrow.
Old Feb 18, 2011 | 09:27 PM
greystreak92
Yeah, I hear some of the parts are Venezuelan! Can you imagine?
Old Feb 19, 2011 | 11:20 AM
b4hntn's Avatar
b4hntn
On mine, i could not get the cooler tubing reconnected until I unclamped the tubing from the frame in front. Then it screwed in straight.
Old Feb 19, 2011 | 01:41 PM
Encho's Avatar
Encho
I think i will need an extrator to take the (!%"#%"#$%"/) Pitman arm from the sector shaft... Any extractor will do?. Damn... everything was so easy until i reached that point, now i'll have to stop until i buy an extractor .
Old Feb 19, 2011 | 03:17 PM
NASSTY's Avatar
NASSTY
This style is the easiest to use but it is also the most expensive.
Old Feb 19, 2011 | 07:35 PM
Encho's Avatar
Encho
Wow... most of those things go for $200 on the net (US), but here in Venezuela i found a simpler model being sold at around $26 (found out i also need a 3/4 socket, $5). I will try to buy one tomorrow... Darn, i wanted to finish this job today... now i'm not even sure if i will be able to finish it this weekend (public transportation near my home sucks... and everything is way too far...).
Old Feb 20, 2011 | 02:56 PM
b4hntn's Avatar
b4hntn
Heat helps removing the pitman arm.
Old Feb 21, 2011 | 12:54 PM
Encho's Avatar
Encho
Ok... the universal extractor that i was using wasn't very good, so i went and returned it, bought myself a pitman arm extractor ($13.77). It seems very robust this one, still, i'll try to use a clamp on it so the arms don't spread. I'll wait an hour or so and will go fight with that darned thing again.
Old Feb 21, 2011 | 04:32 PM
Encho's Avatar
Encho
The "robust" extractor broke... i'll have a word with the vendor tomorrow, as he said it had no warranty.
