1978 - 1996 Big Bronco
Need help, Steering Box
Old Feb 28, 2011 | 12:08 AM
  #31
greystreak92's Avatar
greystreak92
Hallelujah! Time for a BEER! I'd have been screaming at the damned thing..."I win!, I win, I WIN..." followed by a string of expletives.
Old Feb 28, 2011 | 02:18 PM
  #32
Encho's Avatar
Encho
The Southernmost Mod
By that time i just wanted to go home... working on your own truck is quite a complete excercise... But i know the battle isn't over yet, still feels real good. I will start the rebuild today, don't have a proper workplace to wrestle the box, but i think i'll manage.
Old Mar 1, 2011 | 06:50 PM
  #33
FourXFord2's Avatar
FourXFord2
Sounds like your having too much fun Encho! Good luck with the rebuild! Maybe get some anti seize for the splines when you put it back so next time it won't test your tools as much, don't get the anti on the threads.
Old Mar 1, 2011 | 07:04 PM
  #34
BaronVonAutomatc's Avatar
BaronVonAutomatc
Two words for you: PB Blaster.
Old Mar 1, 2011 | 09:14 PM
  #35
Encho's Avatar
Encho
You see? the reason i'm rebuilding my box is because it's leaking steering fluid down the sector shaft. So the arm and shaft where lubbed enough already, PB Blaster wouldn't do a thing for me. A torch could help you, but i wouldn't like any of my parts to loose their temper and become weaker. i'll post some pics soon so you can check how i mounted the extractor in order to be able to apply maximum torque, that and the proper tools will make you manage it in no time.
P.S.: A friend lended me a nice corner in his house to work on my box, i've even managed to take a lot of pics (i'll be sharing them all soon). The rebuild has been going alright, yet i had to stop because i required a tool i didn't have (solved that today). I will continue tomorrow and hope to finish at least the box.
Old Mar 2, 2011 | 07:55 PM
  #36
Encho's Avatar
Encho
Ok, the Steering box is complete, sadly the kit i bought didn't have any new bearings, but the ones in there where like new and made no noise at all... actually all the gears and everything else except the busted seal where in perfect condition. Now, i wonder which would be the better way to put the steering box and all the steering back in place? i'm thinking about the procedure to put the pitman arm back and putting everything else in place. Any ideas? advices?.
Old Mar 3, 2011 | 05:56 PM
  #37
Encho's Avatar
Encho
Anyone? i guess i'll consult the Haynes on this one before trying anything, just to make it easier on me.
On edit: Hmmm... After checking the Haynes i see it's pretty much what i had in mind, i'll let you guys when i'm done, i will be trying to do this tomorrow when i get back from college (or... maybe i'll skip tomorrow and work on the truck).
On other matter: the threads on the bolts felt a little rough when i assembled the box back, which lubricant do you recomend to keep them in good shape and to keep moisture (and rust) out?.
Old Mar 3, 2011 | 06:08 PM
  #38
b4hntn's Avatar
b4hntn
I have no idea if this is the best because I have done it only once. Throw a board across both fenders. Attach the box to a ratchet strap and the ratchet strap to the board for support. Bolt it to the frame. I you have difficulty starting the tubing fittings loosen the clamp holding the cooling tubing to the frame. Install pitman arm and torque to specs.
Old Mar 3, 2011 | 07:08 PM
  #39
BaronVonAutomatc
Some anti-seize compound on the bolts should help for a good while, but there's no way to keep water out forever. Heck, with luck you wouldn't need to loosen them for another 20 years.
Old Mar 3, 2011 | 07:34 PM
  #40
Encho's Avatar
Encho
Thx Baron, i think anti-seize should be fine (even though it's kind of expensive and hard to find around these parts), i'll try to buy a tube tomorrow.
Old Mar 3, 2011 | 07:56 PM
  #41
b4hntn's Avatar
b4hntn
Forums are wonderful...I put thread locker on my bolts.
Old Mar 5, 2011 | 02:43 PM
  #42
Encho's Avatar
Encho
Wrap it up guys! it's over!... man i'm glad i'm done with this... well not totally, the high pressure hose has a little leak so i guess it's time for a new one. But for now i'm done. i took LOTS of pics, so i'll try to do a write-up on my experience soon.
Old Mar 5, 2011 | 05:18 PM
  #43
b4hntn's Avatar
b4hntn
Cellllll----e--bration time (there's a party going on) Trust me, I don't sing well. Congratulations.
Old Mar 7, 2011 | 11:29 AM
  #44
Encho's Avatar
Encho
I need to adjust the Sector Shaft Adjusting Screw, as the return (re-centering) of my steering wheel doesn't feel fast enough, to do so i should do it counter clock wise (like loosing the screw, but actually tightening the steering), am i right? i'll go check anyway.
Old Mar 8, 2011 | 01:52 PM
  #45
Encho's Avatar
Encho
Hmmm... i was right... but the stop nut won't budge without moving the screw along... I guess i'll have to try something else to stop one and move the other.
