Back to stock coil question
OK... my MSD Blaster 2 coil took a dump on me this weekend and I had to get her running so I bought an oem style coil from Napa for $20. I am running the MSD 6A ignition also. It seems to run fine and I just wanted your expert opinions and see if that stock coil is going to be a reliability issue with the combo I have. I don't have a problem ordering a new MSD coil but if it isn't really needed I will just leave it alone. It isn't a beast but does have an Edlebrock performance kit.... intake, carb, cam etc. 351M. Thanks guys.
Hey bud I got this one 8145C superstock chrome. However if I had it available I would have gotten 140207 specific for the duraspark ignition. It even has the horseshoe connecter and I wouldn't of had to cut my wires and wire them to my coil. As a result I am not sure if I lost my tach function or not, but I am sure that I can back wire it somehow. I will just have to see.
Oh, and about the ballast question...?
If you use your original factory harness to feed the coil +, you do not need a resistor, it's built into the harness.
If you have modified the harness, or are using a different hot wire to feed the coil +, then yes you need a resistor, either one built into the coil, or go buy one of those large white chrysler coil resistors and mount it on the firewall.
The DSII system does require 1.05-1.15 ohms resistance in the hot wire feeding the coil to limit the current through the coil and the DSII box.
@Franklin2
The Accel part number Glovemeister provided for the DSII coil is here:
Accel 140207 Racing Coil Ford DuraSpark
This is what always confuses me. It doesn't mention resister needs one way or another, or does it? I'm not sure if I know how to read an ad like this one. What is it that I'm looking at?
Could you explain it a little better for me?
Thanks!
Thanks!
mike460
03-12-2003 11:55 AM
