Dome/Map light question
Old Feb 14, 2011 | 01:56 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Best to get the lamp assymbly from a pickup.
1980-1996 will work.
You can use the lamp assymblies from a car or a bronco, but the map lights will be aimed slightly in the wrong position.
Old Feb 14, 2011 | 04:00 PM
BikeMaker's Avatar
BikeMaker
Do the dome lights in a regular cab truck sit flat on the ceiling, or do they sit at an angle? If that's the case, the angles could be off. I don't see it being an issue on a crew cab or extended cab.
Old Feb 14, 2011 | 04:28 PM
Diesel_Brad's Avatar
Diesel_Brad
On a angle
Old Feb 14, 2011 | 05:23 PM
Fordzilla80's Avatar
Fordzilla80
Cars, Broncos, Supercabs, and Crewcabs will all have the same angle dome light. Single cabs are by themselves.
You have to look very carefully at the lights, it's easy to mistake the differences and use the wrong one. The map lights on the ones from cars/broncos/etc will just point at the visors in a single cab, rendering them quite useless. The single cab light may work in a supercab/bronco/crewcab/car, but I imagine the map lights will just point at the back of the seats.
Old Feb 14, 2011 | 10:47 PM
smashclash's Avatar
smashclash
internals from one of the car domes can't be bent around to accommodate a single cab? or can the internals of a chromed single cab be transferred over to one of the newer plastic housings? like the 2nd post in this thread?
Old Feb 15, 2011 | 01:28 PM
Fordzilla80
No, the housings are completely different.
The light on the left is from a single cab. The one on the right is from a Car/Bronco/Supercab/Crewcab.
jybroncos17
Ford Truck Parts for Sale
Sep 12, 2015 10:01 AM
snakedoc
16
Oct 22, 2013 09:18 PM
Anafiel
1978 - 1996 Big Bronco
Mar 13, 2013 06:43 PM
Diesel Digger
Feb 11, 2012 11:50 PM
mrwake
24
Mar 2, 2008 07:50 PM
