side projects. Whatcha been working on?
Old Aug 10, 2018 | 12:33 PM
  #706
Garden Spyder's Avatar
Garden Spyder
I tried to replace brakes on the trailer last night, and thought I had allowed plenty of time, but only got one side off, and partially installed. I need to buy a brake adjustment tool to adjust the shoes on it. I kept pulling the hub off of it, but that got to be old real quick.
Its held on by 4 bolts, first three came off hot, but came off. fourth one got to the end of the bolt and then the bolt started turning. I tried to grab it with vice grips, I tried to cut it off with an air chisel, I got out a cutoff wheel and finally cut it off. I am glad the new assembly was a replacement for the old one or I might have been in some hurt, trying to repair the damage I did to the old assembly trying to get it off. I think it will be Saturday evening or Sunday before I can return on that project.
Old Aug 10, 2018 | 02:43 PM
  #707
74 bronco's Avatar
74 bronco
my cents repack the bearings while you are there.
Old Aug 10, 2018 | 08:47 PM
  #708
Garden Spyder
I will be doing that! Thanks!
Old Aug 11, 2018 | 07:04 AM
  #709
Flip4ford's Avatar
Flip4ford
I need to get bearings done on mine or at least checked :-)
Today is work on explorer day! gotta get it ready for trip in Oct. Looks I am gong to Iowa Monday going to pick up a toy and have a great road trip
Old Aug 11, 2018 | 07:20 AM
  #710
Garden Spyder
So... We are going? I need to let work know.
Old Aug 12, 2018 | 06:38 PM
  #711
Flip4ford's Avatar
Flip4ford
Poop accelarator position sensor crapped out-- in the super pickle-- O'Rileys could special order one for $208- :-( Got the tire repaired for 10.00 so at least that's good - gotta love unlimited lifetime mount and balance :-)
Old Aug 12, 2018 | 08:36 PM
  #712
wpnaes's Avatar
wpnaes
ML320 water pump with 18 fasteners, dang if one didn’t get stuck in the block...
Old Aug 16, 2018 | 07:02 AM
  #713
Flip4ford's Avatar
Flip4ford
OH dang! DId you get it?
Old Aug 16, 2018 | 08:02 AM
  #714
Garden Spyder
Dude!! That sucks!!
Could you grab it with a pair of Vice grips and pull it out, or did you have to drill and tap?
Nevermind. I see the shiny metal parts. Looks like someone had a baaaaad day.
Old Aug 16, 2018 | 08:43 AM
  #715
husker's Avatar
husker
There is always that one that won't come out.
Old Aug 16, 2018 | 09:01 AM
  #716
wpnaes's Avatar
wpnaes
It took me 2 days, a few drill bits, & a new angled drill motor, but got it opened and tapped. The 3 heater hoses were on back order, so will drain the old fluid again and pop those in this week. Also replaced the Thermostat (must buy housing too), viscus fan clutch, 2 idlers, overflow tank, serp belt, changed the oil... Seriously thought about replacing the original alt. and ps pump (260K miles) but got lazy...
Old Aug 17, 2018 | 08:31 AM
  #717
Flip4ford's Avatar
Flip4ford
Glad you got it fixed
Old Aug 23, 2018 | 09:02 AM
  #718
Flip4ford's Avatar
Flip4ford
Went to back to school night last night- was ok- I like her new teacher. Came home and did some designing for rack to hold camper. wonder if I will need jack to hold truck steady?
Old Aug 23, 2018 | 09:06 AM
  #719
Garden Spyder
I would guess that it should hold pretty firm considering that it is a 3/4 ton, where you will need the solid support will be on the extension that folds out. Maybe some 4x4s under the extension, with some kind of adjustable bottoms on them to have them keep tension.
Old Aug 23, 2018 | 10:24 AM
  #720
Flip4ford's Avatar
Flip4ford
got that handled :-)
