Fixed my heater problem
Old Feb 12, 2011 | 04:28 PM
F250_'s Avatar
F250_
I fixed my heater problem. Before I tell all, though, does anything look wrong with this pitcure?
For some reason, I can't seem to upload images right now, so here's a link to the picture.
Old Feb 12, 2011 | 04:37 PM
guitarpicr's Avatar
guitarpicr
Is it the plug with yellow & blue wires?
Old Feb 12, 2011 | 04:40 PM
lee231's Avatar
lee231
x2 on the plug.
Old Feb 12, 2011 | 04:43 PM
JOHN2001's Avatar
JOHN2001
You forgot to plug the dohickey with the blue and yellow lines bavk into the whityamacalit round black thingy.
Old Feb 12, 2011 | 04:47 PM
JOHN2001's Avatar
JOHN2001
I just looked on my truck to verify it to everyone
Old Feb 12, 2011 | 04:50 PM
F250_'s Avatar
F250_
OK... I guess it's as obvious to all you guys as it was to me.
After reviewing the HVAC diagram posted recently in another thread,
https://www.ford-trucks.com/forums/1...ml#post9860321
... it was easy to determine that there was a problem with my vacuum control motor for the Panel/Floor door. I knew it had to be that because I could get air flow in both the panel vents and the defrost vents, and there was adequate system vacuum to switch between those control options for both A/C and defrost.
When I dropped the glove box down, the first thing I saw was that the connector for the vacuum control motor was not in place. It had to have simply vibrated loose because it was working before Chirstmas.
Sooo... I plugged the connector back onto the vacuum control motor (the black thingamajiggy) and I now have heat on the floor again!!
Old Feb 12, 2011 | 04:58 PM
JOHN2001's Avatar
JOHN2001
I though for sure it was a whityamacalit and not a thingamajiggy learn something new every day lol. One set of toasty toes coming right up, lol.
Old Feb 12, 2011 | 05:00 PM
F250_'s Avatar
F250_
The toasty toes were not as much of a need as reduced air flow towards my eyes... my contact lenses have been drying out like crazy with the only source of heat coming through the defrost vents. Now I can drive, see, and stay warm at the same time!!
Old Feb 12, 2011 | 05:28 PM
big poppa's Avatar
big poppa
Glad you got it Pete, I remember not to long ago you were inquiring about that problem and I believe Robin's writeup helped us both find loose vaccum hoses behind the glove box. I like easy fixes....
Snacky
Feb 28, 2015 02:44 PM
FrankTheF100
Apr 27, 2013 02:51 PM
BruceJeremy
1997 - 2003 F150
Jan 30, 2012 10:56 AM
48ATOY
Mar 27, 2008 09:29 PM
MP&C
Sep 6, 2007 08:58 PM
