Heater Core Question
Old Feb 12, 2011 | 11:16 AM
Fat&Bald's Avatar
Fat&Bald
Since the engine is out for a rebuild I'm going to replace the old heater core. It's a '78 F250 with a 400 and factory A\C but I'm removing the A\C stuff. What heater core should I put back in it, an A\C or non-A\C unit?
Does anybody need the A\C stuff I'm removing?
Old Feb 12, 2011 | 11:25 AM
79 f350ts's Avatar
79 f350ts
if its factory air you have a big box on the outer firewall. to go to non air it would leave a HUGE hole in your firewall. easiest route would be to remove evaporator and replace heater core with a factory air one reusing the big factory box. this also makes it easier if you ever decide to reinstall air
Old Feb 12, 2011 | 11:26 AM
kevin316's Avatar
kevin316
I just did the same thing. You will have to put the same type of core in as the other one has the tubes coming out to the side of the core.
Kevin
Old Feb 12, 2011 | 11:34 AM
fmc400's Avatar
fmc400
MSEE
I agree; it's easiest to just keep the factory AC box in place, in which case you'd use a heater core for an AC application (which has the tubes oriented in a different fashion as Kevin explained).
Old Feb 12, 2011 | 05:18 PM
ranger429's Avatar
ranger429
It is possible to get all of the heating stuff from a non A/C truck and cover the hole in the firewall if you really want to get rid of the big box.
Old Feb 13, 2011 | 01:48 PM
Fat&Bald's Avatar
Fat&Bald
Alright, I'll leave the box in place and go with a factory A\C heater core.
Thanks!
Old Feb 13, 2011 | 04:53 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's almost Summer, what do you need heat for?
J/K... I would swap over a non-a/c unit and cover the hole with sheetmetal.
Josh
Ordnance
Oct 3, 2014 01:37 PM
highoctane74
Apr 24, 2013 09:59 PM
sholloway
Jan 4, 2013 06:26 AM
chopped&dropped
Feb 15, 2009 03:22 PM
74fordtruck
Offroad & 4x4
Apr 5, 2005 02:01 PM
