Ospho as a undercoating?
Old Feb 11, 2011 | 08:04 PM
WH90's Avatar
WH90
Ive heard this stuff is great but terribly harmful to humans? What is the easiest / cheapest DIY Undercoating?
Old Feb 11, 2011 | 08:17 PM
rbaker6336's Avatar
rbaker6336
Ospho is good for stopping rust but will burn you skin.I always use thick rubber gloves when using it
After you put it on and it sits a few hours wash it off,let everything dry then top coat it
It will rust again if not painted
Old Feb 11, 2011 | 08:24 PM
WH90's Avatar
WH90
nice, is there any objects i do not need to get it on, what kind of paint do i need to use?
Old Feb 11, 2011 | 08:35 PM
rbaker6336's Avatar
rbaker6336
Some directions here Ospho
If you live in a harsh environment Por15 is a good top coat
A good frame paint also works good
Old Feb 11, 2011 | 09:14 PM
cavitation's Avatar
cavitation
Yes, POR15 works well but it needs to be top coated if any is exposed to sun/UV rays as it will break down. If only used under the truck, don't need it.Two or more thin coats is key with POR 15. It is designed to be applied direct to metal though for its anti rust sealing properties. Definately wear gloves as you will be wearing it for a couple weeks if you get it on your skin and don't get if off right away LOL. Been there and done that!
ralphwy
May 31, 2017 04:41 PM
Richwon4
Apr 14, 2017 10:21 AM
dwil
Apr 2, 2015 10:06 AM
droppedf100
Feb 16, 2012 11:54 PM
351 power
Paint & Bodywork
Nov 4, 2004 10:51 PM
