Sponsored by: Real Truck
code reader fuel pressure 5.4 06 f250
Old Feb 11, 2011 | 01:29 PM
GUNNERDOG's Avatar
GUNNERDOG
Originally Posted by dchamberlain
You are correct that 2.77 kPa is .40 PSI. I'm not a gasser guy, but that's barely enough pressure to measure, much less run an engine on.
I've seen a few instances where OBD-II readers will read a value and then incorrectly assume a unit of measure. I don't know what the 2.77 represents but I really doubt it is kPa. You need to find a better way to read fuel pressure.
Coincidently, 2.77 bar is exactly equal to 40psi....
I am guessing your reader is displaying the wrong units like David said.
Old Feb 11, 2011 | 01:32 PM
dchamberlain's Avatar
dchamberlain
Interesting. 2.77 bar. There is a commonly used unit of measure.
My Edge Evo reports the barometer PID as 13.7 kPa. Now I know that normal atmospheric pressure at my elevation is NOT 13.7 kPa. It is about 13.7 PSI though.
Old Feb 11, 2011 | 01:36 PM
GUNNERDOG's Avatar
GUNNERDOG
As a chemical engineer i actually use Bar/Atm/PSI a lot... i don't use kPa much...
Although 1 Bar = 100kPa, so its not that crazy of a unit. I am actually a little embarrassed i know that off the top of my head I need to get out more.
Jonspony
6.7L Power Stroke Diesel
Jul 24, 2017 09:08 PM
don-ohio
Sep 22, 2016 08:33 PM
command37
Feb 22, 2016 08:35 PM
KCMAGERS
May 8, 2007 12:36 AM
bearbronco
1978 - 1996 Big Bronco
Nov 28, 2001 11:53 AM
