extreme vibration
Old Feb 10, 2011 | 10:03 PM
wreckinball's Avatar
wreckinball
Nailed it! hahaha, been there done that bro! get that steady bearing out and good to go, as for the yoke, it can be stiff to pull out, just get some leverage on it and itll come out, might need to move up and down if it has a groove. if it does, replace.
Old Feb 10, 2011 | 10:13 PM
Jayme Duty's Avatar
Jayme Duty
I have been trying to find other articles on removing the rear yoke and came across somewhere that you have to remove rear tires and support by frame to take all weight and pressure off the rear axle. is this true?
Old Feb 11, 2011 | 07:19 AM
wreckinball
that wasnt the case with mine and shouldnt be the case. if it has ever been taken off, it was probably siliconed on and if so it will be a bear to pull off, leverage leverage. Just dont go crazy with it.
Old Feb 11, 2011 | 08:35 AM
Dave Sponaugle's Avatar
Dave Sponaugle
With floating axles like the 10.25" Sterling has, there is no weight on the axles.
Old Feb 11, 2011 | 10:45 AM
Jayme Duty's Avatar
Jayme Duty
Since this one is shot anyway is it a bad idea to beat it out using blunt force trauma
Old Feb 11, 2011 | 10:56 AM
Phy's Avatar
Phy
Don't get too carried away with the beating. Remember, the pinion bearings are taking the hits too...
Old Feb 11, 2011 | 11:09 AM
snaponprofile's Avatar
snaponprofile
My truck vibrates and shakes at around 95-100mph.
Old Feb 11, 2011 | 11:24 AM
Country_boy_2007's Avatar
Country_boy_2007
its ok once you get these idi's up over about 120 125 they'll line out...
Old Feb 11, 2011 | 01:32 PM
wreckinball
kilometers per hour!! hahaha
Old Feb 11, 2011 | 03:53 PM
IDIDieselJohn's Avatar
IDIDieselJohn
My F250's top speed is 130km/h (75mph) lol drove nice at that speed.
My 89 F150's top speed is 150km/h (95mph) and it's all over the road over 80mph!
Old Feb 11, 2011 | 08:06 PM
Dave Sponaugle
Since you will probably have to have the new one pressed on, pressing the old one off would be my method.
Less chance of damage to anything.
I had a friend try to hammer one off of a 93 150 drive shaft.
After working on it for almost a day, he spent 20 dollars and was done in 30 minutes at the garage with a press.
Old Feb 11, 2011 | 08:29 PM
wreckinball
yeah i cut my old one off, it was stuck as hell and i am no where near a shop. Just made a deep enough cut so as to not cut the shaft, just the bearing and the hit it with a hammer, shattered!! Machine shop from now on!
brandonlear
Jun 22, 2015 08:56 PM
ox1969
Jun 15, 2015 03:29 PM
ranger812572
Apr 26, 2015 07:03 PM
Golden210
Dec 8, 2014 10:14 AM
Argess
Sep 20, 2012 06:18 PM
