c6 tranny leak
Old Feb 9, 2011 | 01:09 PM
axbreck's Avatar
axbreck
c6 tranny leak
My c6 tranny is leaking from the filler tube does anyone know if I have to drain the ATF to change the o-ring ?
Old Feb 9, 2011 | 01:15 PM
78 PEB's Avatar
78 PEB
If you pull the tube without draining it, It will pretty much drain itself down to the level of where the dipstick tube fits. Might be kinda messy but if your fluid is in good shape, it will save you a few $ by not having to buy all new fluid. You'll just have to replace what drained out. Just make sure you put a drain pan under it BEFORE you pull the tube and clean the area around where the tube fits in good, before you remove the tube; to prevent any dirt from getting inside the tranny.
Old Feb 9, 2011 | 04:08 PM
axbreck's Avatar
axbreck
Thanks for the info
ROKRAWL
Apr 7, 2013 10:04 PM
socalflofam
Mar 9, 2009 10:58 PM
djmac
Jun 12, 2007 06:20 AM
jenkinsj
Jul 22, 2005 07:25 AM
comet
Sep 1, 2002 10:00 PM
