tranny leak
Old Mar 9, 2009 | 12:22 PM
socalflofam's Avatar
socalflofam
tranny leak
i have a c-6 and it leaks from passenger side. if i park on a slant with the pass. side higher than the driv. side no leak. its not the cooler lines. any thoughts?
Old Mar 9, 2009 | 12:38 PM
427 fordman's Avatar
427 fordman
?? Fittings cooler lines go in? Pan Gasket?
Old Mar 9, 2009 | 12:41 PM
btorear's Avatar
btorear
may be overfilled, this happened to me two days ago. There's a "relief spout" (for lack of a better descriptive word) just above the front cooler line inlet closer to the topside of the trans. overfilled mine and the trans fluid came spilling out.
Old Mar 9, 2009 | 02:41 PM
socalflofam
not the pan or fittings; i tthought it was the front cooler line. replaced it. its coming from that erea. the over flow sounds more like it. but i've been checking and rechecking the level and i reads correctly.
Old Mar 9, 2009 | 10:58 PM
socalflofam
i parked it last night and it drained fluid. it only leaks when its parked. i just drove it if i wake up tomorrow and it has leaked less than im thinking i overfilled it. maybe my dipstick is the wrong one. my understanding on how to check the fluid is when its hot and shifted thru all the gears a couple of times and then checked in park.
WVU
Oct 11, 2011 07:01 PM
HardScrabble
Aug 29, 2011 10:10 PM
autx790
1978 - 1996 Big Bronco
Feb 18, 2007 07:22 PM
cturk499
Oil & Lubrication
Oct 12, 2004 07:41 PM
horseracer
1997 - 2003 F150
Jun 4, 2004 12:20 PM
