TRANS RANGE SENSOR
Old Feb 9, 2011 | 05:59 AM
m50's Avatar
m50
TRANS RANGE SENSOR
I borrowed a scan tool and got this code from my truck PO 708 transmission range sensor circuit high, I searched and found a post on what it is and how to change it out but my question is the code says TRS circuit high input does this circuit high input part mean anything extra or different?
thanks RB
Old Feb 9, 2011 | 07:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It means one of the circuits to the TRS is shorted to power. That could be a wiring problem or a bad TRS.
Old Feb 9, 2011 | 08:39 PM
Midwest Dually's Avatar
Midwest Dually
Ooo.. A trans engineer! You need to stick around more often! LOL
Old Feb 10, 2011 | 03:20 AM
Mark Kovalsky
I'm only a few posts from 5,000. I think I spend a lot of time here!
Old Feb 10, 2011 | 03:47 AM
Midwest Dually
Can we encourage you to see if you can hit 10,000? You get a free toaster! LOL
Old Feb 10, 2011 | 05:27 AM
m50's Avatar
m50
Thanks Mark, do you think I should replace the TRS as the most probable cause or how would I check the wiring?
RB
Old Feb 10, 2011 | 06:21 PM
Mark Kovalsky
Check each wire for opens, shorts to ground, and shorts to power. Each one needs to be checked from the PCM to the TRS.
Old Feb 11, 2011 | 05:45 AM
m50's Avatar
m50
I hate to sound stupid but, where is the PCM and will the wires be the same color all the way between the PCM and the TRS?
thanks RB
Old Feb 11, 2011 | 12:19 PM
RRranch's Avatar
RRranch
Almost every time I got a circuit high code it was water or ice somewhere it didn't belong. Shorting the circuits to power. Those GM ABS modules are just notorious for it. unhook your pcm connector and check for water or corrosion then work your way down from there. Unhook the batteries first.
Old Feb 11, 2011 | 05:45 PM
Mark Kovalsky
thanks RB
Yes, they are, but if you're going to trace them by wire color you're going to have a very long day and not get the right answer. You need a wiring diagram. I don't have one to send you.
Sgt93
6.7L Power Stroke Diesel
Feb 5, 2018 12:48 AM
deeplist
Apr 29, 2015 02:01 PM
02GrayPowerStroke
Feb 22, 2015 08:58 PM
Krazymaan
Jun 13, 2011 10:19 PM
PowerStroke_KiD
Mar 15, 2011 08:28 AM
