Offroad & 4x4
60f spindles
Old Feb 8, 2011 | 09:30 PM
bendog's Avatar
bendog
60f spindles
I'm running a low pinion, open knuckle, disk brake 60f in my 76 crew cab tow rig. I have to stick with this axle as a high pinion will interfere with my Cummins oil pan, and I'm unwilling to lift it.
Through sheer stupidity I neglected bad bearings and recently damaged my factory spindles. I'm on the hunt for useable replacements, and interested in any possible replacements from other applications.
I vaguely remember some discussion about useing spindles from something else to upgrade to better lockouts. Anyone know of anything else will work?
Old Feb 8, 2011 | 10:08 PM
fatdan460's Avatar
fatdan460
i don't have an answer for you, but there may be one in the pirate 4x4 dana 60 bible. give it a read if you haven't already, full of info.
Pirate4x4.Com - Extreme Four Wheel Drive
Old Feb 8, 2011 | 10:24 PM
alpha/omega's Avatar
alpha/omega
Rich sells new spindles.
DANA 60 FORD 78-87 SPINDLE 700022X
Old Feb 9, 2011 | 10:33 AM
bendog's Avatar
bendog
Thanks, the pirate site skips this axle as undesirable.
I found an E-bay seller who has some spindles, but his part number is different than mine, (I'd list the link, but I really screwed up the Oregon chapter thread by doing that, to see the link, go to the Oregon chapter buy and sell thread) his bearing part numbers however, are the same. He claims that these spindles also fit on a dana 44? I have heard that the axle shafts are the same as a dana 44 in spline count and diameter, so maybe they are just 44 spindles? Ima go to the Timken site and compare bearing pn's.
Old Feb 9, 2011 | 10:41 AM
bendog's Avatar
bendog
So the Timken sit lists all pre-75 F-250's as useing the same bearings, interchangeable spindles?
kioolt
Jun 18, 2015 07:28 AM
scskysc
Jun 13, 2015 02:48 PM
Infinite Monkeys
May 20, 2013 08:03 PM
KC98072
Mar 12, 2013 01:16 PM
eXtremeYJ
Nov 18, 2009 11:35 PM
