Repair/replace spindles on F250?
My wife and I are new owners of a 1970 F250 2WD Camper/Explorer Special and my first task is to do a front disc conversion among other steering improvements.
I picked the front end off of a 1976 F250 as a donor vehicle and got everything from the proportioning block to the radius arms and even the front sway bar.
I'm in the middle of preparing the parts and it turns out the donor spindles are a little worse for wear. The '76 has 1.05 kingpins so my '70 spindles wont exactly work.
It looks as if someone at some point destroyed a wheel bearing or two on the '76 spindles. Not only is the middle of the snout dinked, but the actual bearing mating surface is gouged up which allows the bearing cone to spin on the spindle.
Do the service manuals have tolerance limits for the spindles or does anyone know what they might be?
Can the spindles be turned to another common size bearing that is affordable and available?
Does anyone make replacement OEM spindles or even weld on snouts? I have been looking and even pick-a-part spindles are hard to find.
Thanks,
-Adam
1970 F250 Camper/Explorer Special
Thanks,
-Adam
For 1975 From ser #w40,001 through 1979 F250 dual caliper front end (7500" through 8100" GVW).
RH...D5TZ3105E...marked D5TA3107HA.
LH...D5TZ3106E...marked D5TA3108HA.
Theses two companies show as having BOTH in stock. CALL BOTH OF THEM AND GET THE BEST PRICE. Both parts and freight.
xBob Allen Ford
913-381-3000
xGreen Sales
(800) 543-4959
xBob Allen Ford
913-381-3000
xGreen Sales
(800) 543-4959
These two companies show as having BOTH in stock. CALL BOTH OF THEM AND GET THE BEST PRICE. Both parts and freight.
Bob Allen Ford in Overland Park KS = 913-381-3000 / 800-676-0675.
Green Sales Co. in Cincinnati OH = 800-543-4959 / 513-731-3304.
There are at least two pick-a-part yards on Branford Street in Sun Valley, there's another in San Berdoo.
And btw: Dual piston caliper disc brakes were optional on 1968/72 F250 2WD & F350.
I'm 60 miles north of LA so 'locally' there is only one pick-a-part style JY and a bunch of salvage yards that either want a fortune for spindles [$350] or don't know WTF my parts gopher (wife) is asking for.
I'm almost a dozen spindles in to this now and so far all of them have been marginal at best. So $250 for old stock spindle isn't sounding too bad considering what I have already spent in time and money trying to track down two good spindles.
If all works out well for my first mail-order [$75 old stock] purchase I'll be down to just needing the right side spindle now.
I picked the 75-79 I-beam set-up for a number of reasons not limited to the fact that one was available for a good deal. The larger hardware was a consideration along with having the front sway bar and all of it's attachment hardware.
Live and learn.. I'm doing both..
<hr align="left" noshade="" width="300">
-Adam
-Adam
It's almost time to select my pieces, paint, install and hope for the best.
Are the '76 radius arms the same length as '70 radius arms? There is conflicting info online and I just want to make sure if I use the '76 arms that my wheels won't be located further back in the wheel well...
1965/72 F100/250 2WD / 1973 F100 2WD & F250 2WD without front sway bar.
D5TZ-3A360-A (replaced D4TZ-3A360-A) .. Radius Arm / Obsolete
1974 F100 2WD & F250 2WD without front sway bar / 1975/79 F100/150 2WD / 1975/79 F250 2WD Regular & Crew Cabs / 1975/79 F250 2WD Super Cabs with 6300/6500/6900/7500 lbs. GVWR's
Wildcat Fords
04-24-2017 06:40 AM
hoss73ford
10-19-2015 02:05 PM
Hawkmcgee
09-30-2012 11:22 AM
DansBBF250
01-08-2011 04:01 PM
