so i got a d60 out of 75 f250!! i installed a spool and upgraded my axles to 35 splin since the stock 30 spline wouldnt be strong enough for the 38+ inch tires i wanna put on. to run the 35 spline i either have to machine out the spindle or replace the spindles completely! which i found here: https://www.4wdfactory.com/store/pro...0-Rear-Spindle
is there a specific tool or slide hammer to get the original spindle out of the shaft??
The spindle is welded to the axle tube- requires a lathe/machinist to cut thru weld or possibly a bandsaw to remove.To correctly replace the spindles you will need to obtain or fabricate a line-up bar with adapters that fit the new spindle inside diameter to ensure they are welded on straight!
