460 EFI to Carb conversion
Old Nov 12, 2023 | 06:06 PM
Jayford150's Avatar
Jayford150
4th Gear
1993 f-350
So it's as simple as swapping heads and intake or the adapter kit. Is there anything I got to do to the computer?
Old Apr 14, 2024 | 04:07 PM
chriss155222's Avatar
chriss155222
3rd Gear
efi to carb swap
i have a 89 f350 with the 460 efi and I'm looking into swaping to a carb using the pricemotorsports adapter but i wanted to know if i need to change anything out like fuel regulators or anything on it or if its just remove efi cap off injectors and put the carb on the adapter plate and hook up fuel lines
Old Apr 14, 2024 | 04:21 PM
85e150's Avatar
85e150
What transmission do you have?
And yes, you have to provide the proper fuel pressure for a carb via regulators or different fuel pumps.
Old Apr 14, 2024 | 04:37 PM
chriss155222
3rd Gear
manual so i dont need to worrie about trans just about how to convert it to carb
Old Apr 14, 2024 | 04:38 PM
85e150's Avatar
85e150
Post 12 hits most of the highlights.
Old Apr 14, 2024 | 04:49 PM
chriss155222
3rd Gear
sorry im new here what?
Old Apr 14, 2024 | 07:13 PM
rla2005's Avatar
rla2005
Post# 12 covers a lot of the conversion details you are asking about.
Old May 26, 2024 | 08:04 PM
88.460.danny's Avatar
88.460.danny
1st Gear
Trans kickdown cable
Originally Posted by BLK79
Price does/did make an adapter which allows keeping the stock EFI intake and mounting a carb. I've got two of them on what were previously EFI 460's. Kit comes with the brass plugs for injector holes. Another benefit of adapting an EFI 460 is factory serpentine belt system. And if you prefer a Saginaw P/S pump that pump/bracket can be sourced from an E-series 460.
How did you mount your throttle cable and trans kickdown cable? I'm having trouble finding a bracket
Old Mar 3, 2025 | 12:28 AM
Prof.PickleCopter's Avatar
Prof.PickleCopter
4wd Low
Bump
I would like to know this as well. Installed a 1991 460 EFI in my 84 F250 but trying to figure out mounts and placement.
SlikWillie
May 20, 2019 08:56 AM
DieseLife
Feb 28, 2015 01:44 PM
xavier23
15
Jan 8, 2013 02:29 PM
J Hodges
Mar 21, 2008 07:53 PM
