Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
cold draft by steering column
Old Feb 8, 2011 | 02:46 PM
rc581's Avatar
rc581
hi all
2010 escape limited. does anyone in the colder climates (michigan) notice any type of draft coming in around the steering column? i have checked for any missing plugs ect. around the firewall, but nothing looks out of place. heater is working fine, and no problem with it warming the truck, but this is an extremly cold draft on the legs when the temp drops down around 10 degrees or so. any ideas??
thanks
bob
Old Feb 10, 2011 | 08:01 AM
tomw's Avatar
tomw
While riding as a passenger, I did feel a cold draft directly under the glove box, behind the lower panel. Just reach up while in motion to detect the leak.
I thought it might be the A/C was running in that particular setting, but it did not seem to change when I changed 'mode'. I think there is leakage, but haven't taken the time to investigate yet.
tom
Old Feb 10, 2011 | 08:18 AM
wptski's Avatar
wptski
I seem to remember that same issue on my '97 Ranger.
Old Feb 11, 2011 | 07:44 AM
rc581's Avatar
rc581
thanks for the reply's i will check it out further, and if i find anything, i will post it
thanks
bob
Old Feb 11, 2011 | 09:46 AM
bmuhlbach's Avatar
bmuhlbach
I have the same issue in my Jeep checked it out and what I found is that its the cold air being moved around behind the dash.When the Jeep gets warm issue is gone.
Old Feb 11, 2011 | 04:01 PM
rc581's Avatar
rc581
tx bmuhlbach
this is first winter on it for me, and i have not gone any distance yet ito amount to anything, just short local runs. i will have to try a long run and see what happens.
thanks again
bob
Old Feb 12, 2011 | 03:05 AM
78 PEB's Avatar
78 PEB
I know that the 91 Explorer we used to have as well as our current '01 Explorer leaked air right around the inside door handles. It's a pretty cold draft when the outside temp is below 0...........You'd think Ford would have fixed it in a ten year span. I checked both of them out and the watershields behind the door panels are in place. Does this on both drivers and passenger sides.
1918ALF
Feb 8, 2016 08:58 PM
soupking
Nov 23, 2015 11:42 AM
Blitzcraig
Feb 8, 2012 11:18 PM
F-100CustomCabTBC
16
Mar 16, 2011 11:40 PM
jmadsen
Flathead V8 & Flathead 6
13
May 14, 2008 09:10 PM
