Road Draft Tube
Old Feb 8, 2012 | 02:35 AM
Blitzcraig's Avatar
Blitzcraig
Road Draft Tube
How do I make/install a toad draft tube and is there any benefit to it?
Old Feb 8, 2012 | 02:44 AM
91dirtydiesel's Avatar
91dirtydiesel
Litterealy a tube coming off CDR going Down under the truck, eliminating the possibilities of the stock setup to leak oil into the #7 and #8 cylinders causing potential problems, the idea is to have the "road draft" when driving to suck out the crankcase gasses rather than your intake. Depending on condition of cdr and motor you will most likely have steady white smoke coming from wherever you route the tube ( especially at warm idle) and possibility of leaving oil drops around your driveway. I'd just clean the crd and keep the stock setup.
Old Feb 8, 2012 | 09:37 AM
IDI guy's Avatar
IDI guy
What is the best way to clean your cdr? And if you aren't concerned about dripping oil how benificial is it (what problems does it prevent)?
Old Feb 8, 2012 | 11:18 PM
lemonshindig's Avatar
lemonshindig
He just said it prevents the potential leaking of oil into the #7 and #8 cylinders. Burning oil raises exhaust gas temperatures, and can ruin head gaskets or do other engine harm.
Justin Jones
Jun 4, 2016 04:47 PM
Barney58F100
Oct 17, 2015 10:13 AM
Textile302
Dec 7, 2014 02:38 PM
Jbrown8988
Jul 7, 2011 10:02 PM
Mauch1
1978 - 1996 Big Bronco
Jun 20, 2011 10:54 PM
